Raid 1 (ufs) faillure, which drive?
Be.Art
my FreeNas is giving an alert for a degraded RAID 1 (UFS, IDE drives) but hangs on the detail view.
I cannot see which drive is the problem.
Edit
Strangely, one of the drives (ada3) is showing up in the volume manager as being able to import although it is/should be still in my RAID. Safe to assume the other one is broken?
There is no noticable difference in speed for that raid in use.
Any1?
Dusan
You can try running gmirror status to get more information.
Be.Art
Name Status Components
mirror/IDE DEGRADED ada2 (ACTIVE)
So ada3 ( the other one) is the "bad one"
Thanks for the -quick- advice!
Dusan
ada2 is currently the only drive in the mirror. If ada3 was supposed to be part of the mirror then that is the problematic one.
Be.Art
ok, thx
gonna swap it tomorrow..
