Radarr v3.2 dotnet5 binary / Radarr v4 dotnet6 binary
FrankNAS
THIS IS NOW IN PORTS/PKG. Please see: https://wiki.servarr.com/radarr/installation#freebsd and https://www.freshports.org/net-p2p/radarr/
THIS GUIDE IS OBSOLETE!
YOU CAN USE IT AS AN OUTLINE TO PORTING OTHER DOTNET THINGS TO FREEBSD IF YOU WANT :)
With dotNET5 SDK now building unofficially under FreeBSD (see here if you want the 6 year journey https://github.com/dotnet/runtime/issues/14537) other cool things can now run under FreeBSD.
The first one being: Radarr v3.1 branch! https://github.com/Radarr/Radarr/tree/develop
tarball: https://radarr.servarr.com/v1/update/nightly/updatefile?os=bsd&arch=x64&runtime=netcore (produced by the Radarr team)
tarball GH: https://github.com/Radarr/Radarr/releases/tag/v3.1.0.4893
txz: https://mega.nz/folder/tIpEFSSB#IHx1OjAREnt_Y56PlsKs-g (Software -> Radarrv3-3.1.0.4625_updateable.txz) (produced by me)
Readme:
for best results: read
for an interesting time: YOLO
REQUIREMENTS:
requires from OS: jail with "allow_mlock=1" and "allow_raw_sockets=1" jail host should be FreeBSD 11.4 or FreeBSD 12.2 or newer
requires in jail (if not installing from pkg/txz): libunwind icu libinotify openssl ca_root_nss sqlite3 libiconv mediainfo
requires additional symlink if getting launch errors: "ln -s /usr/local/lib/libsqlite3.so /usr/local/lib/libe_sqlite3"
IF UPGRADING FROM NON-DOTNET RADARR:
BACKUP YOUR DATA FIRST!
"pkg remove radarr"
IF USING TXZ:
"pkg install radarr.version.txz"
use "sysrc" to set radarr_enable, radarr_data_dir, radarr_user, and radarr_group if needed.
use "service radarr start"
IF NOT USING TXZ:
extract ("tar xf" should be fine) Radarr binary blob to: /usr/local/share/ (it should end up as /usr/local/share/Radarr/)
set ownership as ONE of:
root:wheel
radarr:radarr
the first prevents updates but is more accurate to how it would be set by pkg or port install.
the second allows for update but in rare instances can cause problems with daemonizing Radarr
not setting ownership will cause all kinds of problems if opted to keep the ones in the blob
to run as service: create a "radarr" file with u+x and place in /etc/rc.d/ using the block below
use sysrc to change values to fit your setup, do not edit directly unless know what you are doing
service auto-restarts on crashes and should restart on updates assuming ownership is radarr:radarr
#!/bin/sh
# $FreeBSD$
# PROVIDE: radarr
# REQUIRE: LOGIN
# KEYWORD: shutdown
# Add the following lines to /etc/rc.conf.local or /etc/rc.conf
# to enable this service:
# radarr_enable:    Set to YES to enable radarr
#            Default: NO
# radarr_user:    The user account used to run the radarr daemon.
#            This is optional, however do not specifically set this to an
#            empty string as this will cause the daemon to run as root.
#            Default: radarr
# radarr_group:    The group account used to run the radarr daemon.
#            empty string as this will cause the daemon to run with group wheel.
#            Default: radarr
# radarr_data_dir:    Directory where radarr configuration
#            data is stored.
#            Default: /var/db/radarr
. /etc/rc.subr
name=radarr
rcvar=${name}_enable
load_rc_config $name
: ${radarr_enable:="NO"}
: ${radarr_user:="radarr"}
: ${radarr_group:="radarr"}
: ${radarr_data_dir:="/var/db/radarr"}
pidfile="${radarr_data_dir}/${name}_daemon.pid"
pidfile_child="${radarr_data_dir}/${name}_child.pid"
command="/usr/sbin/daemon"
start_precmd=${name}_precmd
radarr_precmd() {
    if [ ! -d ${radarr_data_dir} ]; then
    install -d -o ${radarr_user} -g ${radarr_group} ${radarr_data_dir}
    fi
    export XDG_CONFIG_HOME=${radarr_data_dir}
    rc_flags="-r -f -p ${pidfile_child} -P ${pidfile} /usr/local/share/Radarr/Radarr --data=${radarr_data_dir} --nobrowser >> /dev/null 2>&1 ${rc_flags}"
run_rc_command "$1"
Differences:
tar: just the binaries. if you want to manage everything yourself and know what they are doing in bsdjail
txz: handles depends, service, permissions, and uses pkg platform. for those like me that are too lazy to setup everything from a tarball
PS. mega link also contains other things that now build under dotnet5 for freebsd AND ARE ALSO EXPERIMENTAL
EDIT: APRIL 22 2021:
#1
I plan on splitting the packaging into two different items:
Radarrv3: tracks "master"
Radarrv3-devel: tracks "develop"
THIS IS DIFFERENT THAN WHAT IT IS NOW!
Radarrv3: tracks "nightly"
Radarrv3-devel: does not exist.
This will make it more consistent with FreeBSD ports naming.
#2
I will be moving ports/pkg builds off of mega (because reasons) to GH (because easier for fetch,curl,wget,etc):
Currently stores packages that port maintainers have not yet updated and native FreeBSD dotnet programs.
#3
"Develop" versions (as tarball) can now be directly downloaded from Radarr's GH
EDIT: MAY 14, 2021:
Packaging transition mentioned earlier this year has now occurred!
Tarballs (binary only) can be found both from: https://radarr.video/#downloads-v3-bsd and https://github.com/Radarr/Radarr/releases
Installable txz (binary + service file + depends) can be found on my GH repo: https://github.com/Thefrank/freebsd-port-sooners
Instructions for TrueNAS users that might be less familiar with the general DYI nature of FreeBSD can be found at: https://github.com/Thefrank/freebsd-port-sooners/blob/main/Radarr_Installation_TrueNAS_GUI.md
FreeBSD users: You likely aren't even reading this and already have everything setup to your liking ;)
Unless some new issues pop up, this should be stable enough for anyone to use. I will keep an eye on this topic but radarr's discord server is better for getting general support. There is a #bsd-builds channel if there is something specific to BSD that needs addressing; my GH repo works too if you don't like discord.
Sonimo
Yup, definitely a success. I installed via txz and it works like a charm :)
ornias
I've done some tests on this back in the jailman days.
Back in 11.3 this wouldn't work, due to how used memory was handled differently between linux, and freebsd 11.2/FreeNAS 11.3.
Luckily iX ported some changes which made it work in 12.0.
But to be clear: This most likely won't work on FreeNAS 11.3
Nimmsis
Works great. thx for this.
@FrankNAS is it possible to get some kind of guide for ombi aswell?
I have a feeling you are Thefrank, if that is the case, thank you for your contributions to get .NET core to FreeBSD.
for ombi aswell?
As far as I could see, Ombi has stopped using mono/.NET in version 2 and the current version isn't able to run on platforms other than linux... I may be wrong, but wasn't able to get it going myself (other than version 2).
Nimmsis
it is correct that ombi is moving away from mono, and is using .net core. same as radarr 3 (which this thread is about).
The reason i did ask was that the mega link above included .net core binaries for ombi as well. so those binaries should work.
Very interesting indeed then... maybe I'll have to give it some kind of a try.
FrankNAS
good to hear and yes, I am the same person and thank you!
as for ombi...
that version of Ombi on mega is pretty old and I don't think I have the service file wired up correctly for that lol
I really should rebuild that one, you are welcome to try it tho
I will be moving most of my to GH in the near-ish future as most forum software either de-linkifies the link (most common forum software with anti-spam plugins) or just nukes the post as spam (reddit)
FrankNAS
I updated ombi it was built from tags/v4.0.1275. This is still a pre-release in his github.
Differences: Not built as single-file because self-contained doesnt work with single-file.
I might get around to making a nice package for it if I can get some time
tusca99
Thank you for your work, radarr works great with no issues since I installed it.
For future packages, could you include Lidarr in the list?
As today we have no real way to get 0.8.x working without issues.
I appreciate all you've done and you'll do, thank you very much.
FrankNAS
I am not directly aware of any issues with Lidarr
The ports version seems up to date with GH for "master" labeled releases
GH latest version is v0.8.0.2042
Latest download returned by update URL seems to be v0.8.0.2096
both still appear to be mono and both are "develop" labeled
its internal updater should push you up to one or the other if you move your update branch to "develop" or "nightly"
as making packages using a GH URL is much easier for both me and the ports system I opted for the .2042 version
changes: named lidarr-devel to be more inline with GH labeling remove mono from depends and added USES=mono added CONFLICTS_INSTALL that should bug you about installing with plain lidarr
its in the "!Not dotNET..." folder and 100% a yolo build.
tusca99
Thank you for putting a ready pkg for me, it works great.
Unfortunately mono6.8.0.123 doesn't work as I keep getting API errors with v0.8.
I'll stick with your pkg until there is a net build for bsd.
Nimmsis
im using mono5.20-5.20.1.34, and it works with both sonarr and lidarr
note, remember to lock the sonarr and lidarr package before updating to mono 5.20, since it will otherwise uninstall it
pkg lock -y sonarr-devel
pkg lock -y lidarr
pkg install -y mono5.20-5.20.1.34
FrankNAS
would it be better to repackage with mono5.20 depend? generally `USES` is the preferred method for a case like this but if mono6.8 has too many issues then certainly it would not best to use here.
AirborneTrooper
interested to see if anyone gets Ombi to work. One of those I've been wanting to try for a while on my TrueNAS box. I was able to get Radarr all setup so thank you!
FrankNAS
@AirborneTrooper about a week ago I added an updated Ombiv4 tarball. No installer at this time because Ombiv4 is not fully into production yet.
also: "It works on my system"
Let me know about errors you encounter.
AirborneTrooper
I used that one but nothing is loading. I don’t get any errors when I start ombi but website doesn’t load.
FrankNAS
stupid idea:
using `sh` as your shell try starting it directly from where you extracted it (so just `./Ombi`)
edit: the reason its a stupid idea is because it might be bug I might not be able to fix lol
