onlineforums
- Oct 1, 2017
My FreeNAS Mini XL+ just failed after 7 years of usage or so. I suspect it is the power supply or motherboard and both seem difficult if not impossible to get a direct replacement. I have 8 WD Red drives that I plan to simply move over to a new machine, import my config and be back up and running.
I'm thinking a rack mount option will be better this time as I intend to get a rack to redo my networking equipment using rackable equipment. I have past experiences in a previous job with SuperMicro products and they seem to be a good build. I have also played around with several Dell servers. I'm comfortable building my own custom rack mount machine but don't know the current do's and don'ts in today's world. My requirements are fairly simple:
- TrueNAS is used personally for rsync backups of local machines and NextCloud to backup iPhones. Nothing Mission Critical and having downtime is simply an inconvenience.
- Low power consumption. Where I live the power is very expensive.
- Noise isn't a huge concern although less noise is better. The FreeNAS Mini XL+ was loud and that is about the maximum the new machine should put off.
- ECC memory, 32GB. Bonus if I can use the memory from my defunct FreeNAS Mini XL+ will work: Samsung M391B1G73QH0-YK0Q (8GB per stick and I have 4 sticks)
- Budget between $600 to $1400 I suspect is fair.
