Freenas Mini XL replacement case recommendations
angst911
I'm looking for recommendations to replace the case my current FreeNAS Mini XL (first generation) is running in. My desire is to reuse the current motherboard & core components. I'm find with needing a new power supply. I've already replaced the original motherboard (failed) with a SuperMicro A2SDI-8C-HLN4F Mini ITX board.
Current Setup:
Mini XL with 8x6tb WD REDs in Raid Z2 configuration
Dual MSATA Boot drives
1xSSD Cache drive
10 GB PCI-E Adapter
My goals:
Reduce Temperatures of drives, I'm currently seeing temperatures of 40-43 degrees
Reduce the noise
I'd like to retain hot-swap capabilities and either re-use the existing drive cages or replace with something like ICY Dock or Rosewill makes, but hot-swap is not a requirement
Tower form factor is a must, I don't have a rack to put this in.
I do plan to replace the 8x6tb drives in the near future, they are getting up in age and starting to throw errors, some of which I assume are from the drive temperatures.
