hello all.
i have a quick question regarding the most optimum setup for the freenas system im looking to build. im basing it on
i was planning on filling the docks up with:
i cant see me near future needs expanding past 70-80 odd TB.
but first im just a bit unsure on the best way to set up the vdevs. and what raid level i should use. the system will primarily be used as a media streaming system aswell as a secondary backup from my nas to keep it extra secure (the nas is also backed up offsite) so while data security is important, it is not a critical factor. The total media library is also backed up on a friends system so again, data security is not a critical factor. but i dont want to have to haul the server around for a petty drive failure, i would like it to fail a bit more than just a drive. but i would like the most space available that i can. it will also sync my seedbox back home and run plex server. and just local network file access. thats mostly it.
also, in regards to ssd caching, will i see any benefits to populating the remaining 2 sata ports with ssd's to cache. or should i just get another 2 wd reds and throw them in there.
and on another note, based on the use of the system. will the 32gb of ram suffice? i know that its a thumbrule of 1gb/TB, but the board only supports 32gb. and i know that if its mostly read intensive i could get away with a bit less.
so, to summarize
Jason
- SuperMicro x10sl7-f
- Intel Xeon E3-1231V3
- 32GB Crucial 16GB (4 x 8GB)
- IcyDock MB074SP-B (4 in 3 caddys)
- 12 x 6TB WD Reds
so, to summarize
- how does my system hardware look
- what is the best vdev setup based on the hardware im planning on using
- will i get a benefit from ssd cache
- should i ignore ssd cache and just use another 2 wd reds
- will i get away with 32gb of ram? or should i look for another board?
Jason
