I see that the Mini XL+ has two SSD ports, and it seems like in each you can put either (1) a "normal" SSD, (2) a read cache, or (3) a write cache. I imagine that a common build would be a read cache in one and a write cache in the other. Is there any advantage to putting a particular cache in the internal bay and the other particular cache in the external bay?
And I'm guessing that the configuration of these caches is pretty much automagical?
Finally, I think I know the answer to this one, but I just want to make sure: The "internal TrueNAS M.2 boot device" is not something that would count towards one of the two SSD bays, right?
Thanks in advance.
Thanks in advance.
