Shadowtester
- Sep 30, 2012
I have a media server setup using Mandriva 2011 64bit which I am using sata port multipliers feeding 15 sata hdds for media storage. Currently I have 10 of the drives filled using XFS and JFS file systems the other 5 drives are currently formatted XFS and are empty. I run sabnzb plus, sickbeard, and couchpotato using nfs to allow my media player access the files. My questions are as follows.
1 Does freenas 8 support sata port multipliers?
2 What options are available to transfer the media files off the XFS and JFS drives onto the empty drives formatted ZFS I have 15tb of files that need transfered the empty drives will hold 10tb which will allow me to transfer 6 of the full drives at one time allowing those to be formated ZFS and hold the rest of the media files. Using nfs or samba would be a last resort due to the time required to transfer the files over Ethernet and having to setup a second Linux computer for the file transfer.
My computer hardware
Motherboard Biostar TA75M+ FM1 AMD A75
CPU AMD A8 3850
Ram Patriot 8gb DDR 3 1600
HighPoint Rocket 620 pcie SATA III controller card used for internal os hdd and dvd drive.
3 Rosewill RSV-S5 SATA 3G 2.5" & 3.5" HDD 5-Bay RAID 0/1/5/10/5+spare/Spanning/JBOD Storage Enclosure System with 120mm cooling fan/ Port Multiplier housing the 15 hard drives for media storage.
CPU AMD A8 3850
