Hi Fellow Members:
I have been diligently burning in my hardware for about the past month. Everything was going quite well with all of the various tests. Once I successfully completed the SMART testing (short, long conveyance) and badblocks, I decided to put some mileage on the new drives with the solnet array tests. The very first time I ran the solnet test, I ran into a few issues. I have the Fractal Design 804, which as most of you know has 3 fans that are controlled with a built in three way switch to control the speed of those 3 fans. I noticed that when I would change the speeds with the switch in the back, it would trigger some sense read errors on the drives attached to the M1015. I was into the last part of the test but decided to abort the test and investigate. While I am quite sure the problem was coming from some electrical interference, I have never seen this kind of issue before. I ended up re-routing the cables away from that switch and from what I can tell that has resolved the issue. Now with all of that said, I restarted the solnet test. From what I can tell, everything looked fine up until the last test. I saw a mix of SLOW and FAST results (see below)..I did a search on the forum and have noticed others have experienced similar behavior.
First solnet array output results
I ran the long SMART tests on all of the drives, to ensure that there were no issues and nothing stood out. There were no pending sector counts or retries, frankly nothing that would be worthy of a return or RMA. (those results are attached).
I did make one mistake and had an array defined and mounted raidZ2 (just a test array at this point); but my thought was it could have interfered with end results of solnet array testing.
So, I decided to run the solnet array test for a second complete time, just to see if anything looked out the ordinary. I made certain there were no volumes mounted this time. Again, everything seemed to look OK, (see below) until the last test and that's where once again, the results looked questionable.
Second solnet array output results
PASS 1 PASS 2
Maybe they are fine, and even if they aren't, if the SMART tests come back clean, I guess there is not a whole lot I can do other than make sure email alerting is set up (check) and that I am doing the proper tests at the proper intervals.
I would very much appreciate any input you all might have; I know that @cyberjock has this same model of drive, so I am curious if anything here gives reason for concern?
Incidentally, I attached the output of the smartctl -x files rather than embed them. If you would prefer I embed them as code I can do that instead.
I am running another long SMART test, and I will post those results tomorrow.
Thanks for your feedback!
-Dan
sol.net disk array test v2 1) Use all disks (from camcontrol) 2) Use selected disks (from camcontrol|grep) 3) Specify disks 4) Show camcontrol list Option: Enter grep match pattern (e.g. ST150176): Selected disks: da0 da1 da2 da3 da4 da5 da6 da7 ada0 ada1 <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 0 lun 0 (pass0,da0) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 1 lun 0 (pass1,da1) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 2 lun 0 (pass2,da2) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 3 lun 0 (pass3,da3) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 4 lun 0 (pass4,da4) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 5 lun 0 (pass5,da5) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 6 lun 0 (pass6,da6) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 7 lun 0 (pass7,da7) <WDC WD60EFRX-68L0BN1 82.00A82> at scbus1 target 0 lun 0 (pass8,ada0) <WDC WD60EFRX-68L0BN1 82.00A82> at scbus2 target 0 lun 0 (pass9,ada1) Is this correct? (y/N): Performing initial serial array read (baseline speeds) Mon Jan 30 22:21:16 EST 2017 Mon Jan 30 22:43:50 EST 2017 Completed: initial serial array read (baseline speeds) Array's average speed is 165.032 MB/sec per disk Disk Disk Size MB/sec %ofAvg ------- ---------- ------ ------ da0 5723166MB 165 100 da1 5723166MB 174 105 da2 5723166MB 164 100 da3 5723166MB 164 99 da4 5723166MB 159 96 da5 5723166MB 161 98 da6 5723166MB 172 104 da7 5723166MB 165 100 ada0 5723166MB 161 97 ada1 5723166MB 165 100 Performing initial parallel array read Mon Jan 30 22:43:50 EST 2017 The disk da0 appears to be 5723166 MB. Disk is reading at about 161 MB/sec This suggests that this pass may take around 593 minutes Serial Parall % of Disk Disk Size MB/sec MB/sec Serial ------- ---------- ------ ------ ------ da0 5723166MB 165 161 98 da1 5723166MB 174 169 97 da2 5723166MB 164 160 97 da3 5723166MB 164 160 97 da4 5723166MB 159 154 97 da5 5723166MB 161 158 98 da6 5723166MB 172 168 98 da7 5723166MB 165 160 97 ada0 5723166MB 161 157 98 ada1 5723166MB 165 165 100 Awaiting completion: initial parallel array read Tue Jan 31 11:41:04 EST 2017 Completed: initial parallel array read Disk's average time is 44910 seconds per disk Disk Bytes Transferred Seconds %ofAvg ------- ----------------- ------- ------ da0 6001175126016 45251 101 da1 6001175126016 42373 94 da2 6001175126016 45310 101 da3 6001175126016 45488 101 da4 6001175126016 46635 104 da5 6001175126016 46213 103 da6 6001175126016 43211 96 da7 6001175126016 45676 102 ada0 6001175126016 45760 102 ada1 6001175126016 43181 96 Performing initial parallel seek-stress array read Tue Jan 31 11:41:04 EST 2017 The disk da0 appears to be 5723166 MB. Disk is reading at about 159 MB/sec This suggests that this pass may take around 599 minutes Serial Parall % of Disk Disk Size MB/sec MB/sec Serial ------- ---------- ------ ------ ------ da0 5723166MB 165 159 96 da1 5723166MB 174 166 96 da2 5723166MB 164 160 97 da3 5723166MB 164 162 99 da4 5723166MB 159 160 101 da5 5723166MB 161 175 109 da6 5723166MB 172 174 101 da7 5723166MB 165 173 105 ada0 5723166MB 161 226 141 ada1 5723166MB 165 228 138 Awaiting completion: initial parallel seek-stress array read Fri Feb 3 11:37:27 EST 2017 Completed: initial parallel seek-stress array read Disk's average time is 113705 seconds per disk Disk Bytes Transferred Seconds %ofAvg ------- ----------------- ------- ------ da0 6001175126016 56652 50 ++FAST++ da1 6001175126016 133325 117 --SLOW-- da2 6001175126016 109032 96 da3 6001175126016 56621 50 ++FAST++ da4 6001175126016 184004 162 --SLOW-- da5 6001175126016 56756 50 ++FAST++ da6 6001175126016 150088 132 --SLOW-- da7 6001175126016 67028 59 ++FAST++ ada0 6001175126016 146952 129 --SLOW-- ada1 6001175126016 176589 155 --SLOW--
sol.net disk array test v2 1) Use all disks (from camcontrol) 2) Use selected disks (from camcontrol|grep) 3) Specify disks 4) Show camcontrol list Option: Enter grep match pattern (e.g. ST150176): Selected disks: da0 da1 da2 da3 da4 da5 da6 da7 ada0 ada1 <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 0 lun 0 (pass0,da0) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 1 lun 0 (pass1,da1) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 2 lun 0 (pass2,da2) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 3 lun 0 (pass3,da3) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 4 lun 0 (pass4,da4) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 5 lun 0 (pass5,da5) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 6 lun 0 (pass6,da6) <ATA WDC WD60EFRX-68L 0A82> at scbus0 target 7 lun 0 (pass7,da7) <WDC WD60EFRX-68L0BN1 82.00A82> at scbus1 target 0 lun 0 (pass8,ada0) <WDC WD60EFRX-68L0BN1 82.00A82> at scbus2 target 0 lun 0 (pass9,ada1) Is this correct? (y/N): Performing initial serial array read (baseline speeds) Sun Feb 5 06:31:51 PST 2017 Sun Feb 5 09:54:24 EST 2017 Completed: initial serial array read (baseline speeds) Array's average speed is 165.971 MB/sec per disk Disk Disk Size MB/sec %ofAvg ------- ---------- ------ ------ da0 5723166MB 165 100 da1 5723166MB 174 105 da2 5723166MB 165 99 da3 5723166MB 164 99 da4 5723166MB 159 96 da5 5723166MB 162 98 da6 5723166MB 172 104 da7 5723166MB 166 100 ada0 5723166MB 163 98 ada1 5723166MB 170 102 Performing initial parallel array read Sun Feb 5 09:54:24 EST 2017 The disk da0 appears to be 5723166 MB. Disk is reading at about 166 MB/sec This suggests that this pass may take around 573 minutes Serial Parall % of Disk Disk Size MB/sec MB/sec Serial ------- ---------- ------ ------ ------ da0 5723166MB 165 166 101 da1 5723166MB 174 175 100 da2 5723166MB 165 165 100 da3 5723166MB 164 166 101 da4 5723166MB 159 159 100 da5 5723166MB 162 163 101 da6 5723166MB 172 173 101 da7 5723166MB 166 166 100 ada0 5723166MB 163 162 100 ada1 5723166MB 170 170 100 Awaiting completion: initial parallel array read Sun Feb 5 22:42:21 EST 2017 Completed: initial parallel array read Disk's average time is 44378 seconds per disk Disk Bytes Transferred Seconds %ofAvg ------- ----------------- ------- ------ da0 6001175126016 44721 101 da1 6001175126016 41849 94 da2 6001175126016 44795 101 da3 6001175126016 44958 101 da4 6001175126016 46078 104 da5 6001175126016 45677 103 da6 6001175126016 42678 96 da7 6001175126016 45132 102 ada0 6001175126016 45206 102 ada1 6001175126016 42684 96 Performing initial parallel seek-stress array read Sun Feb 5 22:42:22 EST 2017 The disk da0 appears to be 5723166 MB. Disk is reading at about 160 MB/sec This suggests that this pass may take around 595 minutes Serial Parall % of Disk Disk Size MB/sec MB/sec Serial ------- ---------- ------ ------ ------ da0 5723166MB 165 161 97 da1 5723166MB 174 171 98 da2 5723166MB 165 179 109 da3 5723166MB 164 180 110 da4 5723166MB 159 179 113 da5 5723166MB 162 156 97 da6 5723166MB 172 181 105 da7 5723166MB 166 162 98 ada0 5723166MB 163 165 102 ada1 5723166MB 170 245 144 Awaiting completion: initial parallel seek-stress array read Thu Feb 9 02:16:56 EST 2017 Completed: initial parallel seek-stress array read Disk's average time is 115534 seconds per disk Disk Bytes Transferred Seconds %ofAvg ------- ----------------- ------- ------ da0 6001175126016 171068 148 --SLOW-- da1 6001175126016 67394 58 ++FAST++ da2 6001175126016 118882 103 da3 6001175126016 56520 49 ++FAST++ da4 6001175126016 57467 50 ++FAST++ da5 6001175126016 117406 102 da6 6001175126016 178994 155 --SLOW-- da7 6001175126016 134442 116 --SLOW-- ada0 6001175126016 137955 119 --SLOW-- ada1 6001175126016 115210 100 Taking a closer look, here are the results between each run of the solnet tests.
PASS 1 PASS 2
Disk Bytes Transferred Seconds %ofAvg Disk Bytes Transferred Seconds %ofAvg ------- ----------------- ------- - ------- ----------------- ------- ------ da0 6001175126016 56652 50 ++FAST++ da0 6001175126016 171068 148 --SLOW-- da1 6001175126016 133325 117 --SLOW-- da1 6001175126016 67394 58 ++FAST++ da2 6001175126016 109032 96 da2 6001175126016 118882 103 da3 6001175126016 56621 50 ++FAST++ da3 6001175126016 56520 49 ++FAST++ da4 6001175126016 184004 162 --SLOW-- da4 6001175126016 57467 50 ++FAST++ da5 6001175126016 56756 50 ++FAST++ da5 6001175126016 117406 102 da6 6001175126016 150088 132 --SLOW-- da6 6001175126016 178994 155 --SLOW-- da7 6001175126016 67028 59 ++FAST++ da7 6001175126016 134442 116 --SLOW-- ada0 6001175126016 146952 129 --SLOW-- ada0 6001175126016 137955 119 --SLOW-- ada1 6001175126016 176589 155 --SLOW-- ada1 6001175126016 115210 100
-Dan
