Hi Fellow Members:
I have been diligently burning in my hardware for about the past month. Everything was going quite well with all of the various tests. Once I successfully completed the SMART testing (short, long conveyance) and badblocks, I decided to put some mileage on the new drives with the solnet array tests. The very first time I ran the solnet test, I ran into a few issues. I have the Fractal Design 804, which as most of you know has 3 fans that are controlled with a built in three way switch to control the speed of those 3 fans. I noticed that when I would change the speeds with the switch in the back, it would trigger some sense read errors on the drives attached to the M1015. I was into the last part of the test but decided to abort the test and investigate. While I am quite sure the problem was coming from some electrical interference, I have never seen this kind of issue before. I ended up re-routing the cables away from that switch and from what I can tell that has resolved the issue. Now with all of that said, I restarted the solnet test. From what I can tell, everything looked fine up until the last test. I saw a mix of SLOW and FAST results (see below)..I did a search on the forum and have noticed others have experienced similar behavior.
First solnet array output results
I ran the long SMART tests on all of the drives, to ensure that there were no issues and nothing stood out. There were no pending sector counts or retries, frankly nothing that would be worthy of a return or RMA. (those results are attached).
I did make one mistake and had an array defined and mounted raidZ2 (just a test array at this point); but my thought was it could have interfered with end results of solnet array testing.
So, I decided to run the solnet array test for a second complete time, just to see if anything looked out the ordinary. I made certain there were no volumes mounted this time. Again, everything seemed to look OK, (see below) until the last test and that's where once again, the results looked questionable.
Second solnet array output results
PASS 1 PASS 2
Maybe they are fine, and even if they aren't, if the SMART tests come back clean, I guess there is not a whole lot I can do other than make sure email alerting is set up (check) and that I am doing the proper tests at the proper intervals.
I would very much appreciate any input you all might have; I know that @cyberjock has this same model of drive, so I am curious if anything here gives reason for concern?
Incidentally, I attached the output of the smartctl -x files rather than embed them. If you would prefer I embed them as code I can do that instead.
I am running another long SMART test, and I will post those results tomorrow.
Thanks for your feedback!
-Dan
sol.net disk array test v2
1) Use all disks (from camcontrol)
2) Use selected disks (from camcontrol|grep)
3) Specify disks
4) Show camcontrol list
Option:
Enter grep match pattern (e.g. ST150176):
Selected disks: da0 da1 da2 da3 da4 da5 da6 da7 ada0 ada1
<ATA WDC WD60EFRX-68L 0A82> at scbus0 target 0 lun 0 (pass0,da0)
<ATA WDC WD60EFRX-68L 0A82> at scbus0 target 1 lun 0 (pass1,da1)
<ATA WDC WD60EFRX-68L 0A82> at scbus0 target 2 lun 0 (pass2,da2)
<ATA WDC WD60EFRX-68L 0A82> at scbus0 target 3 lun 0 (pass3,da3)
<ATA WDC WD60EFRX-68L 0A82> at scbus0 target 4 lun 0 (pass4,da4)
<ATA WDC WD60EFRX-68L 0A82> at scbus0 target 5 lun 0 (pass5,da5)
<ATA WDC WD60EFRX-68L 0A82> at scbus0 target 6 lun 0 (pass6,da6)
<ATA WDC WD60EFRX-68L 0A82> at scbus0 target 7 lun 0 (pass7,da7)
<WDC WD60EFRX-68L0BN1 82.00A82> at scbus1 target 0 lun 0 (pass8,ada0)
<WDC WD60EFRX-68L0BN1 82.00A82> at scbus2 target 0 lun 0 (pass9,ada1)
Is this correct? (y/N): Performing initial serial array read (baseline speeds)
Mon Jan 30 22:21:16 EST 2017
Mon Jan 30 22:43:50 EST 2017
Completed: initial serial array read (baseline speeds)
Array's average speed is 165.032 MB/sec per disk
Disk Disk Size MB/sec %ofAvg
da0 5723166MB 165 100
da1 5723166MB 174 105
da2 5723166MB 164 100
da3 5723166MB 164 99
da4 5723166MB 159 96
da5 5723166MB 161 98
da6 5723166MB 172 104
da7 5723166MB 165 100
ada0 5723166MB 161 97
ada1 5723166MB 165 100
Performing initial parallel array read
The disk da0 appears to be 5723166 MB.
Disk is reading at about 161 MB/sec
This suggests that this pass may take around 593 minutes
Serial Parall % of
Disk Disk Size MB/sec MB/sec Serial
da0 5723166MB 165 161 98
da1 5723166MB 174 169 97
da2 5723166MB 164 160 97
da3 5723166MB 164 160 97
da4 5723166MB 159 154 97
da5 5723166MB 161 158 98
da6 5723166MB 172 168 98
da7 5723166MB 165 160 97
ada0 5723166MB 161 157 98
ada1 5723166MB 165 165 100
Awaiting completion: initial parallel array read
Tue Jan 31 11:41:04 EST 2017
Completed: initial parallel array read
Disk's average time is 44910 seconds per disk
Disk Bytes Transferred Seconds %ofAvg
da0 6001175126016 45251 101
da1 6001175126016 42373 94
da2 6001175126016 45310 101
da3 6001175126016 45488 101
da4 6001175126016 46635 104
da5 6001175126016 46213 103
da6 6001175126016 43211 96
da7 6001175126016 45676 102
ada0 6001175126016 45760 102
ada1 6001175126016 43181 96
Performing initial parallel seek-stress array read
Disk is reading at about 159 MB/sec
This suggests that this pass may take around 599 minutes
Serial Parall % of
da0 5723166MB 165 159 96
da1 5723166MB 174 166 96
da3 5723166MB 164 162 99
da4 5723166MB 159 160 101
da5 5723166MB 161 175 109
da6 5723166MB 172 174 101
da7 5723166MB 165 173 105
ada0 5723166MB 161 226 141
ada1 5723166MB 165 228 138
Awaiting completion: initial parallel seek-stress array read
Fri Feb 3 11:37:27 EST 2017
Completed: initial parallel seek-stress array read
Disk's average time is 113705 seconds per disk
da0 6001175126016 56652 50 ++FAST++
da1 6001175126016 133325 117 --SLOW--
da2 6001175126016 109032 96
da3 6001175126016 56621 50 ++FAST++
da4 6001175126016 184004 162 --SLOW--
da5 6001175126016 56756 50 ++FAST++
da6 6001175126016 150088 132 --SLOW--
da7 6001175126016 67028 59 ++FAST++
ada0 6001175126016 146952 129 --SLOW--
ada1 6001175126016 176589 155 --SLOW--
3) Specify disks
Option:
Sun Feb 5 06:31:51 PST 2017
Sun Feb 5 09:54:24 EST 2017
Array's average speed is 165.971 MB/sec per disk
da2 5723166MB 165 99
da5 5723166MB 162 98
da7 5723166MB 166 100
ada0 5723166MB 163 98
ada1 5723166MB 170 102
Disk is reading at about 166 MB/sec
This suggests that this pass may take around 573 minutes
Serial Parall % of
da0 5723166MB 165 166 101
da1 5723166MB 174 175 100
da2 5723166MB 165 165 100
da3 5723166MB 164 166 101
da4 5723166MB 159 159 100
da5 5723166MB 162 163 101
da6 5723166MB 172 173 101
da7 5723166MB 166 166 100
ada0 5723166MB 163 162 100
ada1 5723166MB 170 170 100
Sun Feb 5 22:42:21 EST 2017
Disk's average time is 44378 seconds per disk
da0 6001175126016 44721 101
da1 6001175126016 41849 94
da2 6001175126016 44795 101
da3 6001175126016 44958 101
da4 6001175126016 46078 104
da5 6001175126016 45677 103
da6 6001175126016 42678 96
da7 6001175126016 45132 102
ada0 6001175126016 45206 102
ada1 6001175126016 42684 96
Sun Feb 5 22:42:22 EST 2017
Disk is reading at about 160 MB/sec
This suggests that this pass may take around 595 minutes
Serial Parall % of
da0 5723166MB 165 161 97
da1 5723166MB 174 171 98
da2 5723166MB 165 179 109
da3 5723166MB 164 180 110
da4 5723166MB 159 179 113
da5 5723166MB 162 156 97
da6 5723166MB 172 181 105
da7 5723166MB 166 162 98
ada0 5723166MB 163 165 102
ada1 5723166MB 170 245 144
Thu Feb 9 02:16:56 EST 2017
Disk's average time is 115534 seconds per disk
da0 6001175126016 171068 148 --SLOW--
da1 6001175126016 67394 58 ++FAST++
da2 6001175126016 118882 103
da3 6001175126016 56520 49 ++FAST++
da4 6001175126016 57467 50 ++FAST++
da5 6001175126016 117406 102
da6 6001175126016 178994 155 --SLOW--
da7 6001175126016 134442 116 --SLOW--
ada0 6001175126016 137955 119 --SLOW--
ada1 6001175126016 115210 100
Taking a closer look, here are the results between each run of the solnet tests.
PASS 1 PASS 2
Disk Bytes Transferred Seconds %ofAvg Disk Bytes Transferred Seconds %ofAvg ------- ----------------- ------- - ------- ----------------- ------- ------ da0 6001175126016 56652 50 ++FAST++ da0 6001175126016 171068 148 --SLOW-- da1 6001175126016 133325 117 --SLOW-- da1 6001175126016 67394 58 ++FAST++ da2 6001175126016 109032 96 da2 6001175126016 118882 103 da3 6001175126016 56621 50 ++FAST++ da3 6001175126016 56520 49 ++FAST++ da4 6001175126016 184004 162 --SLOW-- da4 6001175126016 57467 50 ++FAST++ da5 6001175126016 56756 50 ++FAST++ da5 6001175126016 117406 102 da6 6001175126016 150088 132 --SLOW-- da6 6001175126016 178994 155 --SLOW-- da7 6001175126016 67028 59 ++FAST++ da7 6001175126016 134442 116 --SLOW-- ada0 6001175126016 146952 129 --SLOW-- ada0 6001175126016 137955 119 --SLOW-- ada1 6001175126016 176589 155 --SLOW-- ada1 6001175126016 115210 100
-Dan
