Hi
Building my first FreeNAS and need help going from zero 2 hero.
Looking at 14 x 3TB drive internal plus 8 x 3TB external via eSATA (if OK - see other post) for a total of 22 drives.
I'm assuming I should go RAIDZ2 over RAIDZ at least.
Does FreeNAS self defrag drives and check for bad sectors and identify, notify and repair?
I see from the FAQ that the best way to identify a failed drive is to note it's serial number. It would seem that I should write down all serial numbers of drives when building system and keep this document so I know which one to pull. Any other tricks or am I on the right path?
It appears all drives need to be the same size or else smallest drive determines capacity of all drives - is this right?
I was looking at adding external 4 bay enclosures via eSATA in RAID 5 for additional redundancy but now assume this would be pointless as they need to be JBODs.
How do I get notified when a drive goes bad - do I get emailed?
I looked under 4.1 Reporting and 9.6 Alert in 8.0.3 Guide cursory glance but couldn't see where this is mentioned and may have missed it.
For RAIDZ2 is capacity roughly n-2?
(so 22 x 3TB = 66 - 6 = 60TB)
Cheers
Cheers
