I recently bought a used Dell Poweredge R510 which came equipped with a PERC H700. I have never seen a controller that couldn't do pass-through or JBOD, so needless to say I'm pretty bummed with what I ended up with. I'm aware that the instructions here state to not get an H700, I found these instructions after the fact.
My question is, what's a good controller to replace this with? I was reading that an H200 would be a good solution, but the post was dated and I was wondering if there would be a more modern, speedier solution.
Also, I want to ensure that the H200, or whatever is (hopefully) recommended, will in fact fit and work with an R510.
Lastly, some of the disks I wish to use do not have TLER. Which has never been a problem for me in a JBOD scenario, I want to also make sure that whatever controller I get will not cause issues if this feature isn't available. I assume that if it does passthrough fine then it shouldn't be a problem but you guys would know better than I if there's some hiccup I'm not aware of here.
EDIT: Not sure if this is relevant but the existing card can/is currently supporting 14 SAS/SATA drives. So the new one would need at least that much capability as well. I'm installing two SSD's in RAID0 for the OS, so ideally that would be supported at maximum throughput.
Thanks in advance,
Sunspot
Thanks in advance,
Sunspot
