jbdimanche
- Jun 9, 2012
I wasn't sure where to put this, and I searched the FAQs for this but couldn't find it. I am using Freenas 8.2.0b3 64 bit with 8 gigs of RAM with only 2 TB of data ZFS in stripe formation. Basically it is nothing more than a network storage to drop files until I store them later in a more permanent solution.
Autotune set the vfs.zfs.arc_max to 5008060544 and vm.kmem_size to 4865441894. My question is this, would there be any advantage to increasing these values? I notice from the memory graph it never uses more than the allocated memory. I do not run any plugins or other apps. Thank you for any opinions that anyone might have.
