i have a server with two pools. i set up replication from one to the other just so i have an independent copy (backup is elsewhere).
the main pool is encrypted, the 2nd pool is not (at least not the pool)
when replicated it creates datasets on the target pool that are encrypted via the same key as on the source pool. makes sense and works properly
my question; if the 2nd/target pool was encrypted, would the replicated data set still have its own encryption key from the source pool? or would it just rely on the encryption of that drive? i dont have a spare system to test this on at the moment...
thanks for any help
thanks for any help
