Greetings
I'm seeking some advice regarding the upgrade process for my TrueNAS server.
I'm planning to perform a motherboard update, and here are the key specifications:
I've noticed some users exporting their pools and then reimporting them onto the new system. I'm a bit unsure about the reasoning behind this step. As far as I can tell, the only scenario where this would be necessary is when migrating the pool to a different TrueNAS installation. That case would essentially be the same as scenario 2, but without restoring the old configuration, instead importing the exported pool into the new TrueNas instance. Is my understanding correct?
I appreciate any insights or guidance on this matter. Thank you in advance.
- 3x PCIe LSI Controller (all drives are connected to them)
- 2x SATA SSDs (boot pool) connected to the motherboard
- 1x U.2 Optane (SLOG) connected to PCIe via an adapter card
- 1x PCIe 10G Intel x520-da1 NIC
- Swap out the motherboard and reconnect everything
- Swap out the motherboard and reconnect everything except the 2 boot SSDs. Install a fresh TrueNAS on 2 new SSDs, then restore the configuration from the old system.
