SwisherSweet
- May 13, 2017
Hi folks,
I am looking at adding a desktop JBOD enclosure to expand storage. I found that QNAP has several (4, 8, and 18 drive) options, each including an expansion card. Here's the 16 bay, for example:
Says it supports Windows and Linux. It's my understanding that TrueNAS Scale is built on Linux, so does anyone see any reason this should not work with TrueNAS Scale? Assume that I have a working TrueNAS Scale server with an available PCIe slot (x16).
Seems like worst case scenario I'd need to buy an expansion card that supports TrueNAS and sell the one that came with it. If this is my best chance of getting this to work, any suggestions for a port that will work with TrueNAS Scale with 4 ports to connect to this 16 bay unit?
Thank you.
Thank you.
