QNAP QTS vs FreeNAS on a TS-853A
ech1965
I'm thinking scratching QTS and put FreeNAS on my TS-853A ( 4x3TB and 4x2TB)
For the record:
CPU Intel N3150, 16GB RAM, 4 E1000 ethernet, USB2&3
My plan is to use a USB thumb drive for my tests and if it's successful, buy a EUSB DOM and replace the QNAP DOM with a bigger one storing FreeNAS os...
Is it Powerful enough ?
Any experience ?
I plan to host docker containers/jail/plugins
* basic file sharing
* syncthing
* medusa
* transmissionbt
Thanks in advance for your help and info!
EC
Chris Moore
I have a QNAP system that I have been considering doing this with. It has a Xeon CPU and 16GB of RAM. It is the system board that worries me. It has video output but it never showed me anything during power up. I didn't know if it would boot from some other device.
ech1965
Thanks for the feedback.
I already booted an ubuntu live usb ( display showing on hdmi output). eg: for testing the memory upgrade to 16GB
The TS-853A has a "normal pc bios" configurable using the HDMI output and a usb keyboard...
I'm busy moving all my data an will try "soon" !
Chris Moore
Did you need to do anything special to get it to boot from the USB device instead of their boot module?
ech1965
No, exactly like a PC ...
Here is what I did
- power off
- unplug all hard disks
- plug in USB keyboard (in one port on the back)
- plug in USB stick 8GB (back of device)
- plug in usb stick containing FreeNAS installer (front port)
- plug in HDMI screen in one of the HDMI ports
power on
as soon as the numlock LED lights -->> I started hammering the Del key
After a few seconds ( longer than a normal PC mainboard), I got a BIOS config screen
There you can change the boot order
In the Save/Exit menu, there is a "boot override" menu where you can override the boot order for ONE boot!
I successfully
- booted the installer
- install FreeNAS on the stick
- boot from the stick
- connect to the web UI from another PC
I didn't start configuring the hard disks, I'd need to remove my "production" disks from the caddies and pu spare disk ... just to play with FreeNAS ;-)
It looks like it could be possible to replace the DOM with such an thing [1]
I need to finish moving my data out of the qts configuration before going further with FreeNAS on QNAP...
Good night !
EC
[1] https://www.befr.ebay.be/itm/New-Ki...odule-16GB-9-Pins-EUSB-DOM-Flash/192473833942
Denko
Hi
I have just installed FreeNAS on my qnap ts-253a and it works just fine for now. I've upgraded the ram to 16gb and installed the OS on a samsung evo850 250gb via USB. I'm planning to use it as a media server so any advice on any plugins, setup, do's and don'ts will be much appreciated. I will slowly try and transfer data across as I don't want to go through the trouble of transferring it all and then screw up the setup and have to start again.
ech1965 how is yours working so far? Any tips?
Thank you and looking forward to your replies.
Chris Moore
You might want to start a thread of your own so people are not replying to your post in this thread, which might cause confusion as your questions are likely different from the ones that @ech1965 might have.
Chris Moore
Any experience ?
Based on your experience, I gave it a try with a QNAP system I have access to and I ran into a few issues that I think are hardware compatibility. The unit I have is a 16 bay rack mount and it has a hot-swap backplane that connects directly to the system board with an edge connector. The system board has a lot of fairly standard looking features including the RAM (DDR3 ECC) and the Xeon E3 processor, but FreeNAS is not able to properly recognize the disk interface. It is being detected as SATA, when I thought it was SAS, but it will also not enable the SMART service under services which is preventing FreeNAS from running any SMART tests on the drives. It is also reporting in the log, "Error synching enclosure: 'notivier' object has no attribute 'zpool_enclosure_sync'.
I have only been tinkering with it for a couple days. Most features work, but a couple that I think are important, like SMART testing the drives, are not working.
I know that you already have it, so your situation is different, but for most people I would say that the QNAP hardware could be an option, if they can get a great deal on it, but it isn't ideal for FreeNAS because of some potential hardware incompatibility.
UPDATE: I looked through the log file and found that the system has 7 Marvel 88SE9125 SATA controllers (2 ports each) and the Intel chipset controller with 6 ports. There are 2 rear eSATA ports (probably from one of the Marvell controllers and 2 internal SATA ports on the system board, so the remaining ports are somehow wired to the hot-swap backplane to control the 16 drives in it. To me, this doesn't sound like a good hardware solution and certainly not a good solution for FreeNAS.
This is for the model I have, other models may differ, your mileage may vary.
ech1965
Some news:
I'm slowly finding my way in freenas ( busy right now studying iocage ..) so I do not have advices for you ( but any tuto about freenas would fit...)
As far as hardware support is concerned: See bellow for the lspci ( TS-853A)
Ethernet are recognized (I put all 4 in a lagg0 lacp on my dlink DGS1210)
LCD screen stuck a "SYSTEM BOOTING"... need to find ou how to port/adapt this
https://forum.qnap.com/viewtopic.php?f=147&t=76581
I'l keep this post updated ....
EC
* here follows a list of pcidevices
oot@lorath:~ # lspci -v
00:00.0 Host bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SoC Transaction Register (rev 21)
Subsystem: Intel Corporation Device 7270
Flags: bus master, fast devsel, latency 0
00:02.0 VGA compatible controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller (rev 21) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at 80000000 (64-bit, non-prefetchable)
Memory at 90000000 (64-bit, prefetchable)
I/O ports at f000
Capabilities: [d0] Power Management version 2
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [b0] Vendor Specific Information: Len=07 <?>
00:03.0 Multimedia controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Imaging Unit (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at 81000000 (32-bit, non-prefetchable)
Capabilities: [80] Power Management version 2
00:10.0 SD Host controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series MMC Controller (rev 21) (prog-if 01)
Memory at 81e27000 (32-bit, non-prefetchable)
Capabilities: [80] Power Management version 3
00:13.0 SATA controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SATA Controller (rev 21) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
I/O ports at f060
Memory at 81e24000 (32-bit, non-prefetchable)
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
00:14.0 USB controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller (rev 21) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 20
Memory at 81e00000 (64-bit, non-prefetchable)
Capabilities: [70] Power Management version 2
Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
00:18.0 DMA controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 DMA Controller (rev 21) (prog-if 02 [EISA DMA])
Memory at 81e18000 (32-bit, non-prefetchable)
00:18.2 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller #2 (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at 81e23000 (32-bit, non-prefetchable)
00:18.3 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller #3 (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 255
Memory at 81e22000 (32-bit, non-prefetchable)
00:18.4 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller #4 (rev 21)
Memory at 81e21000 (32-bit, non-prefetchable)
00:18.6 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller #6 (rev 21)
Memory at 81e20000 (32-bit, non-prefetchable)
00:18.7 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller #7 (rev 21)
Memory at 81e1f000 (32-bit, non-prefetchable)
00:1a.0 Encryption controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Trusted Execution Engine (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 21
Memory at 81500000 (32-bit, non-prefetchable)
Memory at 81400000 (32-bit, non-prefetchable)
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit-
00:1b.0 Audio device: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio Controller (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 22
Memory at 81e14000 (64-bit, non-prefetchable)
Capabilities: [50] Power Management version 2
Capabilities: [60] MSI: Enable- Count=1/1 Maskable- 64bit+
00:1c.0 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #1 (rev 21) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: 81d00000-81dfffff [size=1M]
Prefetchable memory behind bridge: None
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Intel Corporation Device 7270
Capabilities: [a0] Power Management version 3
00:1c.1 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #2 (rev 21) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Memory behind bridge: 81c00000-81cfffff [size=1M]
00:1c.2 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #3 (rev 21) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=08, sec-latency=0
I/O behind bridge: 0000a000-0000cfff [size=12K]
Memory behind bridge: 81900000-81bfffff [size=3M]
00:1c.3 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #4 (rev 21) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 19
Bus: primary=00, secondary=09, subordinate=0e, sec-latency=0
I/O behind bridge: 00007000-00009fff [size=12K]
Memory behind bridge: 81600000-818fffff [size=3M]
00:1e.0 DMA controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO1 DMA Controller (rev 21) (prog-if 02 [EISA DMA])
Memory at 81e10000 (32-bit, non-prefetchable)
00:1e.3 Communication controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO1 HSUART Controller #1 (rev 21)
Memory at 81e1e000 (32-bit, non-prefetchable)
00:1e.4 Communication controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO1 HSUART Controller #2 (rev 21)
Memory at 81e1d000 (32-bit, non-prefetchable)
00:1f.0 ISA bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCU (rev 21)
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
00:1f.3 SMBus: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx SMBus Controller (rev 21)
Flags: medium devsel, IRQ 18
Memory at 81e1c000 (32-bit, non-prefetchable)
I/O ports at f040
Capabilities: [50] Power Management version 3
01:00.0 SATA controller: Marvell Technology Group Ltd. Device 9215 (rev 11) (prog-if 01 [AHCI 1.0])
Subsystem: Marvell Technology Group Ltd. Device 9215
I/O ports at e050
I/O ports at e040
I/O ports at e030
I/O ports at e020
I/O ports at e000
Memory at 81d10000 (32-bit, non-prefetchable)
Expansion ROM at 81d00000 [disabled]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Express Legacy Endpoint, MSI 00
Capabilities: [e0] SATA HBA v0.0
02:00.0 SATA controller: Marvell Technology Group Ltd. Device 9215 (rev 11) (prog-if 01 [AHCI 1.0])
I/O ports at d050
I/O ports at d040
I/O ports at d030
I/O ports at d020
I/O ports at d000
Memory at 81c10000 (32-bit, non-prefetchable)
Expansion ROM at 81c00000 [disabled]
03:00.0 PCI bridge: ASMedia Technology Inc. Device 1184 (prog-if 00 [Normal decode])
Bus: primary=03, secondary=04, subordinate=08, sec-latency=0
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Upstream Port, MSI 00
Capabilities: [c0] Subsystem: ASMedia Technology Inc. Device 118f
04:01.0 PCI bridge: ASMedia Technology Inc. Device 1184 (prog-if 00 [Normal decode])
Bus: primary=04, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 0000c000-0000cfff [size=4K]
Memory behind bridge: 81b00000-81bfffff [size=1M]
Capabilities: [80] Express Downstream Port (Slot+), MSI 00
04:03.0 PCI bridge: ASMedia Technology Inc. Device 1184 (prog-if 00 [Normal decode])
Bus: primary=04, secondary=06, subordinate=06, sec-latency=0
I/O behind bridge: 0000b000-0000bfff [size=4K]
Memory behind bridge: 81a00000-81afffff [size=1M]
04:05.0 PCI bridge: ASMedia Technology Inc. Device 1184 (prog-if 00 [Normal decode])
Bus: primary=04, secondary=07, subordinate=07, sec-latency=0
I/O behind bridge: 0000a000-0000afff [size=4K]
Memory behind bridge: 81900000-819fffff [size=1M]
04:07.0 PCI bridge: ASMedia Technology Inc. Device 1184 (prog-if 00 [Normal decode])
Bus: primary=04, secondary=08, subordinate=08, sec-latency=0
I/O behind bridge: None
Memory behind bridge: None
05:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
Memory at 81b00000 (32-bit, non-prefetchable)
I/O ports at c000
Memory at 81b80000 (32-bit, non-prefetchable)
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=5 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
06:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
Memory at 81a00000 (32-bit, non-prefetchable)
I/O ports at b000
Memory at 81a80000 (32-bit, non-prefetchable)
07:00.0 SATA controller: Marvell Technology Group Ltd. Device 9215 (rev 11) (prog-if 01 [AHCI 1.0])
I/O ports at a050
I/O ports at a040
I/O ports at a030
I/O ports at a020
I/O ports at a000
Memory at 81910000 (32-bit, non-prefetchable)
Expansion ROM at 81900000 [disabled]
09:00.0 PCI bridge: ASMedia Technology Inc. Device 1184 (prog-if 00 [Normal decode])
Bus: primary=09, secondary=0a, subordinate=0e, sec-latency=0
0a:01.0 PCI bridge: ASMedia Technology Inc. Device 1184 (prog-if 00 [Normal decode])
Bus: primary=0a, secondary=0b, subordinate=0b, sec-latency=0
I/O behind bridge: 00009000-00009fff [size=4K]
Memory behind bridge: 81800000-818fffff [size=1M]
0a:03.0 PCI bridge: ASMedia Technology Inc. Device 1184 (prog-if 00 [Normal decode])
Bus: primary=0a, secondary=0c, subordinate=0c, sec-latency=0
I/O behind bridge: 00008000-00008fff [size=4K]
Memory behind bridge: 81700000-817fffff [size=1M]
0a:05.0 PCI bridge: ASMedia Technology Inc. Device 1184 (prog-if 00 [Normal decode])
Bus: primary=0a, secondary=0d, subordinate=0d, sec-latency=0
I/O behind bridge: 00007000-00007fff [size=4K]
Memory behind bridge: 81600000-816fffff [size=1M]
0a:07.0 PCI bridge: ASMedia Technology Inc. Device 1184 (prog-if 00 [Normal decode])
Bus: primary=0a, secondary=0e, subordinate=0e, sec-latency=0
0b:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
Memory at 81800000 (32-bit, non-prefetchable)
I/O ports at 9000
Memory at 81880000 (32-bit, non-prefetchable)
0c:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
Memory at 81700000 (32-bit, non-prefetchable)
I/O ports at 8000
Memory at 81780000 (32-bit, non-prefetchable)
0d:00.0 SATA controller: Marvell Technology Group Ltd. Device 9215 (rev 11) (prog-if 01 [AHCI 1.0])
I/O ports at 7050
I/O ports at 7040
I/O ports at 7030
I/O ports at 7020
I/O ports at 7000
Memory at 81610000 (32-bit, non-prefetchable)
Expansion ROM at 81600000 [disabled]
ech1965
Quick Update:
* Freenas installed
* LACP OK ( 4 ethernets)
* Still no progress with LCD ( System booting)
* Minor issue with HDD leds: Leds for HDD 1 & 2 aren't blinking on hdd access. ( steady on ...)
Off topic: Now working on scripts to deploy jails using iocage
Cheers
EC
