qBittorrent will not start
da_da
After changing IP of the jail, the qbittorrent will not start... what would be the cause?
so I ran the command below from the jail, and I get the message below:
root@qbittorrent:/usr/local # service qbittorrent start
Cannot 'start' qbittorrent. Set qbittorrent_enable to YES in /etc/rc.conf or use 'onestart' instead of 'start'.
not sure why changing IP causes the the service not to start.
I say this thread where someone mentioned to run:
iocage exec $JAIL sysrc qbittorrent_enable="YES"
How do I do that from the jail???
OK, so I ran the jexec 8 sysrc qbittorrent_enable="YES"
and it worked, but now I am not able to login... so, I presume this is set back to default???? why???
Login to what? The qBittorrent web interface? Get what back? The torrents? The downloaded files?
da_da
yes, yes, yes, and yes.
I can login to the Web interface now but all the 20 torrents that are in the .config direcotory are not showing up on the list. looks like I lost the configuration of the qbt.
What ".config" directory? If you're running qbittorrent-nox as a service (daemon), then it is likely looking under here (inside the jail) for its settings, cache, and torrents:
/var/db/qbittorrent/
(There are more subfolders within.)
da_da
Question is, All I did was change the IP of the jail, so why nothing is working?
da_da
all the old torrents are under /.local/share/qBittorrent/BT_Backup.
I'm not sure why changing the IP address would do any of that, but from what it looks like, you might have previously been running qbittorrent-nox as the root user, but not as a daemon/service. This is why you have config files and references inside the root user's home directory (i.e, ~/.local/share/).
From the get-go, you should have been running qbittorrent-nox strictly as a daemon service (i.e, via rc.d), in which everything is located under /var/db/qbittorrent/.
da_da
I installed it using the default plugin. I have not made any changes when I installed it originally. How do I get back to where I was? is there a documentation on how to recover?
Can someone point me to how I can recover my configs and files?
You're using different directories:
Check the contents under /root/.local/share/, and look for a qBittorrent folder. You can try copying this folder to /var/db/qbittorrent/conf/ (and make sure to recursively change its ownership to qbittorrent:qbittorrent)
I'd recommend you first stop the service and rename/delete the currently existing folder under /var/db/, so for example:
service qbittorrent stop
mv -v /var/db/qbittorrent/conf/qBittorrent /var/db/qbittorrent/conf/qBittorrent.new
Followed by:
cp -v -a /root/.local/share/qBittorrent /var/db/qbittorrent/conf/
Finally:
chown -R qbittorrent:qbittorrent /var/db/qbittorrent
service qbittorrent restart
Your situation might call for different commands and locations.
da_da
Everything is set to default. I have not done anything other than change IP.
da_da
Followed by:
Finally:
Thanks for this but non this helped... I compared the files and they are all default config. I have the torrent files but none are recognized.
Just OMG, Watta crappy app.
Thanks anyways for trying.
