DeltaEntropy
- Mar 27, 2022
Hi.
I'm running TrueNAS-13.0-U2, with qbt (4.3.8) and Filebot (4.9.6) running in a jail.
I've had qbt running an external program/command before, just a simple
I've tried the suggestions on the Filebot AMC guide, but nothing seems to work.
I've also tried having qbt run a script which runs filebot, I've confirmed that the script calls filebot correctly but can't get qbt to run it.
I've checked the logs of qbt and it says that it has executed the command, I've also checked the filebot (amc.log) and it confirms that it hasn't done anything.
Has anyone managed to get qbt to run filebot?
Thanks
cp
command but still, so I know that works. I've also been using Filebot from the CLI in the jail just fine, does everything perfectly.I've tried the suggestions on the Filebot AMC guide, but nothing seems to work.
Thanks
