PULL Replication Task Issues
My Pull task is working. But i dont want to delete snapshots based on time. For the source system i dont mind but on the destination i want to delete snapshots based on the number of snapshots. As example i only want to keep the last 3 snapshots on backup server. That way if the pull fails for whatever reason they are not deleted after 2 days like the source. On the source it keeps snapshots for 2 days this is fine because it runs every day. But for the Pull on destination server i want it to pull everyday but keep the last three snapshots not follow source and use time based. Any ideas? Why isnt there an option that says keep last amount of snapshots?
Patrick M. Hausen
You could write a shell script executed by cron that does that.
Can you give me a hint on that. Also if I do that do I just set retention policy in replication to none since I'm letting cron Handle deletion
I figured it out for anyone needing the cron job command here it is....
zfs list -H -o name -t snapshot | grep <dataset_name>@ | sort -r | awk 'NR>3' | xargs -n 1 zfs destroy -r
Just replace the <dataset_name> with the path of your dataset.
