Last login: Sat Mar 28 18:20:06 on pts/0
FreeBSD 11.3-RELEASE-p6 (FreeNAS.amd64) #0 r325575+d5b100edfcb(HEAD): Fri Feb 21 18:53:26 UTC 2020
        FreeNAS (c) 2009-2020, The FreeNAS Development Team
        All rights reserved.
        FreeNAS is released under the modified BSD license.
        For more information, documentation, help or support, go here:
http://freenas.org
Welcome to FreeNAS
Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
root@FREENAS1[~]# testparm -e
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
# Global parameters
[global]
        aio max threads = 2
        bind interfaces only = Yes
        disable spoolss = Yes
        dns proxy = No
        enable web service discovery = Yes
        kernel change notify = No
        load printers = No
        logging = file
        max log size = 51200
        restrict anonymous = 2
        server min protocol = SMB2_02
        server role = standalone server
        unix extensions = No
        idmap config * : backend = tdb
        allocation roundup size = 0
        directory name cache size = 0
        dos filemode = Yes
        include = /usr/local/etc/smb4_share.conf
[Pool1]
        aio write size = 0
        ea support = No
        guest ok = Yes
        guest only = Yes
        mangled names = illegal
        path = /mnt/Pool1/Public
        read only = No
        guest ok = Yes
        guest only = Yes
