ccssid
- Dec 12, 2016
Hello everyone,
I just built up my FreeNAS box a bit ago for plex and storing misc docs, music and videos. Everything is working great, thanks to all of you on this forum.
using 10 @ wd red x 3tb (z2 setup) and here is the rest of the story.....
https://www.newegg.com/Product/Product.aspx?Item=N82E16822236344
https://www.newegg.com/Product/Product.aspx?Item=N82E16817994080
https://www.newegg.com/Product/Product.aspx?Item=N82E16835553001
https://www.newegg.com/Product/Product.aspx?Item=N82E16813599008
https://www.amazon.com/SanDisk-Ultr...coding=UTF8&psc=1&refRID=5GJJRSE17DBTPCZ8P333
https://www.newegg.com/Product/Product.aspx?Item=N82E16819117613
https://www.newegg.com/Product/Product.aspx?Item=N82E16817151119
https://www.newegg.com/Product/Product.aspx?Item=N82E16835856005
https://www.newegg.com/Product/Product.aspx?Item=N82E16814131709
https://www.amazon.com/gp/product/B00009MDBU/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00H3SWJ24/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00YQ7D5Y6/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B002RL8I7M/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
https://www.amazon.com/Cable-Matter...rd_wg=kwo8r&psc=1&refRID=2B399FDX2C3C82RWX747
https://www.newegg.com/Product/Prod...escription=rosewill+blackbone&N=-1&isNodeId=1
note: the case I had laying around for several years so I decided to use it and outfit t with a couple of extra fans and the 3.5" adapters in order to fit the 10 hard drives. beleive it or not, it works out pretty good. here are my idle temps.
and
I have to change one more fan for the da2 and da3 drives with one more of the cougar fans.
my point is.......the "kill-a-watt" shows a max at start-up of 184 watts, and at idle 92 watts (also taking into accout a cyberpower cp1500c....which shows about 6.3 watts just by itself)
why is it , after foraging through this forum I find that everyone is of the opinion that I should have at least at 650 to 750 watt psu ??????
But when I search the net......some think a 350 watt psu is more than enough.
what am I missing here ?
btw: never have had a hickup yet in the system...albeit only been in use a couple of weeks.
thanks
sid
[root@freenas ~]# sysctl -a |grep temper dev.cpu.7.temperature: 27.0C dev.cpu.6.temperature: 27.0C dev.cpu.5.temperature: 22.0C dev.cpu.4.temperature: 22.0C dev.cpu.3.temperature: 21.0C dev.cpu.2.temperature: 21.0C dev.cpu.1.temperature: 22.0C dev.cpu.0.temperature: 23.0C [root@freenas color:white">[root@freenas ~]# echo "HDD temp :" HDD temp : [root@freenas ~]# for i in $(sysctl -n kern.disks) > do > DevTemp=`smartctl -a /dev/$i | awk '/Temperature_Celsius/{print
and
> DevSerNum=`smartctl -a /dev/$i | awk '/Serial Number:/{print $0}' | aw k '{print $3}'` > DevName=`smartctl -a /dev/$i | awk '/Device Model:/{print $0}' | awk ' {print $3}'` > echo $i $DevTemp $DevSerNum $DevName > done da4 da3 31C WD-WCC4N4RXK45H WDC da2 36C WD-WCC4N0KUJ173 WDC da1 35C WD-WCC4N5CH8P2L WDC da0 28C WD-WCC4N1UH2182 WDC ada5 33C WD-WCC4N5CJ3ELS WDC ada4 31C WD-WCC4N3DU7TXY WDC ada3 27C WD-WCC4N4KH7YPJ WDC ada2 28C WD-WCC4N4TZ3C85 WDC ada1 34C WD-WCC4N3DU77SE WDC ada0 31C WD-WCC4N4RJ8TV8 WDC [root@freena
thanks
sid
