Bidule0hm
Server Electronics Sorcerer
- Aug 5, 2013
Failing that, why wouldn't CH1-CH2 with AC coupling enabled work?
Because you can't be AC coupled (the peak is 100s of ms long) and if you DC couple you'll be limited by the resolution of the ADC (and 99% of the scopes use 8 bits ADC so when you are at 2 V/div the LSB is about 60 mV, at best) so if you use a shunt of 20 mOhms for example (because you can't use 1 Ohm for example, at 1 A you'll be at 11 V on the drive --> already out of the ATX spec) your resolution will be 3 A and actually there's to much noise to even see a 3 A change... I tested it, it's just impossible to extract something useful with this method.
Incidentally, just in case it wasn't obvious, that was actually a compliment.
Oh, totally missed that, so, thanks ;)
Does it have to be copper twisted pair, or is the Cat. 5 part just what you had at hand?
Actually you only need one of the 8 wires :)
Can I upgrade it to fiber? :p
No, but I see what you did there... :p
