process kills and hangouts
emi
i have change the os from debian to freenas to use zfs sensible. Now is the system complete and all services run! The system is only for backup services! I have rsync tasks, nfs+samba shares and one iscsi lun on one vol. All services run on the same zfs pool. i use a lot of memory and the cpu load, caching is ok. The system is up2date(FreeNAS-11.0-U3 (c5dcf4416)) and have two Xeon E5506 cpus. The controller is a LSI MegaRAID SAS 9261-8i anbd all disks are raid0 arrays.
index.php
index.php
index.php
root@XXXXXXX:/var/log # mfiutil show volumes
mfi0 Volumes:
  Id  Size  Level  Stripe  State  Cache  Name
mfid0 (  930G) RAID-0  64K OPTIMAL Writes
mfid1 (  930G) RAID-0  64K OPTIMAL Writes
mfid2 ( 1862G) RAID-0  64K OPTIMAL Writes
mfid3 (  930G) RAID-0  64K OPTIMAL Writes
mfid4 (  930G) RAID-0  64K OPTIMAL Writes
mfid5 (  930G) RAID-0  64K OPTIMAL Writes
mfid6 (  930G) RAID-0  64K OPTIMAL Writes
mfid7 (  930G) RAID-0  64K OPTIMAL Writes
mfid8 (  930G) RAID-0  64K OPTIMAL Writes
mfid9 (  930G) RAID-0  64K OPTIMAL Writes
mfid10 (  930G) RAID-0  64K OPTIMAL Writes
mfid11 ( 1862G) RAID-0  64K OPTIMAL Writes
mfid12 ( 1862G) RAID-0  64K OPTIMAL Writes
mfid13 ( 1862G) RAID-0  64K OPTIMAL Writes
mfid14 ( 1862G) RAID-0  64K OPTIMAL Writes
mfid15 ( 1862G) RAID-0  64K OPTIMAL Writes
But i have hangouts and process kills. VMs get to read only file systems and some process (which using nfs and samba shares) have timeouts.
(0:3:0/0): READ(10). CDB: 28 00 00 00 ae 58 00 00 01 00
(0:3:0/0): Tag: 0xa95947, type 1
(0:3:0/0): ctl_process_done: 179 seconds
(0:3:0/0): Tag: 0xa9594a, type 1
(0:3:0/0): ctl_process_done: 139 seconds
(0:3:0/0): Tag: 0xa9594d, type 1
(0:3:0/0): ctl_process_done: 99 seconds
ctl_datamove: tag 0xa95994 on (0:3:0) aborted
ctl_datamove: tag 0x385b3604 on (3:3:0) aborted
ctl_datamove: tag 0x385b3605 on (3:3:0) aborted
ctl_datamove: tag 0x385b3606 on (3:3:0) aborted
ctl_datamove: tag 0x385b3607 on (3:3:0) aborted
ctl_datamove: tag 0x385b3608 on (3:3:0) aborted
ctl_datamove: tag 0x385b3609 on (3:3:0) aborted
What can i do? What is wrong?
Artion
I don't know if this can help but I see in the forum that for LSI raid controllers is recomended to use them in IT mode that requires flashing them with an appropriate firmware.
The SAS 926x constrollers do not support IT mode.
Artion
Just for curiosity: why you have a pool with two raidz1 vdevs which one have 10 drives and the other 6? Is there any perfomance gain by having this configuration?
emi
Thanks for the answers!! #artion: The disks have different sizes. i had try it with one raidz1 and so but the problems were the same. The disks have different sizes.
my last test was wit an other controller (LSI SAS 9205-8e in it mode) . but i think the controller had problems with the expander. :-(
index.php
