maxxoverclocker
- Feb 28, 2014
Hi all! I'm experiencing a strange issue with l2arc that began after the 9.10.2 update. I was wondering if anyone else had experienced the same. Basically after a few days of running, FreeNAS suddenly thinks that 700GiB of l2arc has magically transformed into 32EiB (Exabytes!!!) of l2arc. Then over the course of a few weeks, I begin experiencing ctl_datamove errors when clients using iscsi/nfs/smb protocols do deletes. This results in disk I/O timeouts for my VMs running on the vmfs datastores running off the NAS. I also begin noticing very sporadic and unpredictable performance from the pool while this is occuring, ranging from 200MiB/s -> 100KiB/s while doing large sequential writes. I found this thread: https://forums.freenas.org/index.ph...results-in-ctl_datamove-tag-on-aborted.40119/ which seems very similar to what I'm experiencing, however I'm not using any link aggregation protocols, nor is auto-negotiate set for my interface.
I'm using two 350GiB partitions on two separate disks for the l2arc.
Here is an example before a reboot (32EiB) note that it even says that 1,851/700GiB are consumed somehow:
and after a reboot (700GiB):
You can see this started happening right after I installed 9.10.2 on December 27th.
To give you a little background this is occurring on a pool consisting of two raidz2 groups of 6 drives each (12 disks total). This is my home NAS that just hosts media, crashplan backups, and esxi datastores for test/dev/experimentation. I'm not overly concerned with the data in the pool. My average block size is very large due to this being primarily a media server so the l2arc tables use very little memory. I'm not worried about the large size of l2arc. It uses less than 1G of memory to maintain the 700G of l2arc.
os: FreeNAS-9.10.2-U1 (86c7ef5)
cpu: Intel i3-6320 CPU @ 3.90GHz
memory: 64GiB of ECC
nic: Intel 10Gbase-SR
hba(s): LSI SAS2008
Here's what I get in the logs:
Any ideas? Seeing anything similar?
[root@NAS] ~# zpool iostat -v volsata01
capacity operations bandwidth
pool alloc free read write read write
cache - - - - - -
gptid/58469bd6-9166-11e6-b0a2-0cc47abd1c65 926G 16.0E 21 10 1.57M 1.21M
gptid/5c02b182-9166-11e6-b0a2-0cc47abd1c65 925G 16.0E 20 10 1.57M 1.21M
-------------------------------------- ----- ----- ----- ----- ----- -----and after a reboot (700GiB):
cache - - - - - -
gptid/58469bd6-9166-11e6-b0a2-0cc47abd1c65 5.94M 350G 0 0 618 36.7K
gptid/5c02b182-9166-11e6-b0a2-0cc47abd1c65 5.29M 350G 0 0 618 37.2K
-------------------------------------- ----- ----- ----- ----- ----- -----You can see this started happening right after I installed 9.10.2 on December 27th.
hba(s): LSI SAS2008
Feb 10 14:46:35 NAS Feb 10 14:46:35 NAS ctl_datamove: tag 0x1630b33 on (0:4:0) aborted
Feb 10 14:46:35 NAS Feb 10 14:46:35 NAS ctl_datamove: tag 0x1630b34 on (0:4:0) aborted
Feb 10 14:46:35 NAS Feb 10 14:46:35 NAS ctl_datamove: tag 0x4b054c on (1:4:0) aborted
Feb 10 14:46:35 NAS Feb 10 14:46:35 NAS ctl_datamove: tag 0x1630b32 on (0:4:0) aborted
Feb 10 14:46:35 NAS Feb 10 14:46:35 NAS ctl_datamove: tag 0x1630b31 on (0:4:0) aborted
Feb 10 14:46:35 NAS Feb 10 14:46:35 NAS ctl_datamove: tag 0x1630b30 on (0:4:0) aborted
Feb 10 14:46:23 NAS Feb 10 14:46:23 NAS (0:4:0/0): ctl_process_done: 102 seconds
Feb 10 14:46:23 NAS Feb 10 14:46:23 NAS (0:4:0/0): Tag: 0x16300f2, type 1
Feb 10 14:46:23 NAS Feb 10 14:46:23 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 09 08 f4 e8 00 00 08 00
Feb 10 14:46:23 NAS Feb 10 14:46:23 NAS (0:4:0/0): ctl_process_done: 100 seconds
Feb 10 14:46:23 NAS Feb 10 14:46:23 NAS (0:4:0/0): Tag: 0x1630aad, type 1
Feb 10 14:46:23 NAS Feb 10 14:46:23 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 10 1d 2e 90 00 00 18 00
Feb 10 14:46:23 NAS Feb 10 14:46:23 NAS (0:4:0/0): Tag: 0x16302ea, type 1
Feb 10 14:46:23 NAS Feb 10 14:46:23 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 16 81 ac 18 00 00 20 00
Feb 10 14:46:23 NAS Feb 10 14:46:23 NAS (0:4:0/0): Tag: 0x16300ec, type 1
Feb 10 14:46:23 NAS Feb 10 14:46:23 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 05 70 58 00 00 00 10 00
Feb 10 14:46:23 NAS Feb 10 14:46:23 NAS (1:4:0/0): ctl_process_done: 91 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (1:4:0/0): Tag: 0x4b0536, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (1:4:0/0): READ(10). CDB: 28 00 00 00 a9 b8 00 00 01 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (1:4:0/0): ctl_process_done: 92 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (1:4:0/0): Tag: 0x4b0533, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (1:4:0/0): COMPARE AND WRITE. CDB: 89 00 00 00 00 00 00 00 a9 b8 00 00 00 01 00 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): ctl_process_done: 101 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x16303c2, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 18 33 31 40 00 00 68 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): ctl_process_done: 100 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630aae, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): READ(10). CDB: 28 00 05 0f 62 00 00 01 00 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): ctl_process_done: 97 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630abb, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 00 4c 9a 58 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): ctl_process_done: 102 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x16300ed, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 05 70 99 30 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x16300f1, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 08 e3 7d 20 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x16300ee, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 06 ad 38 18 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x16300ef, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 08 e3 59 00 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x16300f5, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 0a ea 38 20 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): ctl_process_done: 91 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630ac1, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 01 c2 fe 4f 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630abf, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 0b bf 78 d8 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630abe, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 0b bf 78 b8 00 00 10 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630abd, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 00 a3 10 b8 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630abc, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 00 a3 10 18 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630aba, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 18 76 d9 68 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630ab9, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 18 72 73 a0 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (1:4:0/0): ctl_process_done: 100 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (1:4:0/0): Tag: 0x4b0531, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): ctl_process_done: 96 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630aae on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630ab8, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): ctl_datamove: 98 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 18 72 46 d8 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630abb on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): ctl_datamove: 96 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630ab4, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 18 0f e0 00 00 00 10 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ad3 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ad1 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630ab7, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630acf on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630acd on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630aca on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ac8 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ac6 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ac4 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ac1 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630abf on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630abe on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630abd on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630abc on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630aba on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 18 72 33 68 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ab9 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ab8 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ab4 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): ctl_datamove: 95 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x4b0531 on (1:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ab7 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630ab6, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 18 72 31 30 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): ctl_process_done: 95 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ab6 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630ab5, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 18 72 30 38 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630ab3, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ab5 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 00 00 e9 1d 00 00 01 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x16300f4, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 09 f2 28 28 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ab3 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630ab2, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 01 c2 ff 53 00 00 01 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ab2 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630ab1, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 08 fb 15 d8 00 00 10 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630ab0, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ab1 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): COMPARE AND WRITE. CDB: 89 00 00 00 00 00 00 00 ab f8 00 00 00 01 00 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): Tag: 0x1630aaf, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 00 00 e9 b5 00 00 01 00
Feb 10 14:46:22 NAS Feb 10 14:46:22 NAS ctl_datamove: tag 0x1630ab0 on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:21 NAS (0:4:0/0): ctl_datamove: 97 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:21 NAS (0:4:0/0): Tag: 0x16300f0, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:21 NAS (0:4:0/0): Tag: 0x1630ab0, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:21 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 08 e3 73 78 00 00 08 00
Feb 10 14:46:22 NAS Feb 10 14:46:21 NAS (0:4:0/0): COMPARE AND WRITE. CDB: 89 00 00 00 00 00 00 00 ab f8 00 00 00 01 00 00
Feb 10 14:46:22 NAS Feb 10 14:46:21 NAS (0:4:0/0): ctl_process_done: 100 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:21 NAS ctl_datamove: tag 0x1630aaf on (0:4:0) aborted
Feb 10 14:46:22 NAS Feb 10 14:46:21 NAS (0:4:0/0): Tag: 0x16300f6, type 1
Feb 10 14:46:22 NAS Feb 10 14:46:21 NAS (1:4:0/0): ctl_datamove: 98 seconds
Feb 10 14:46:22 NAS Feb 10 14:46:21 NAS (0:4:0/0): Tag: 0x1630aae, type 1
Feb 10 14:46:21 NAS Feb 10 14:46:21 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 0e bc 1b 50 00 00 08 00
Feb 10 14:46:21 NAS Feb 10 14:46:21 NAS (0:4:0/0): ctl_datamove: 97 seconds
Feb 10 14:46:21 NAS Feb 10 14:46:21 NAS (0:4:0/0): ctl_process_done: 100 seconds
Feb 10 14:46:21 NAS Feb 10 14:46:21 NAS (0:4:0/0): Tag: 0x1630aaf, type 1
Feb 10 14:46:21 NAS Feb 10 14:46:21 NAS (1:4:0/0): Tag: 0x4b0531, type 1
Feb 10 14:46:21 NAS Feb 10 14:46:21 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 00 00 e9 b5 00 00 01 00
Feb 10 14:46:21 NAS Feb 10 14:46:21 NAS (0:4:0/0): READ(10). CDB: 28 00 05 0f 62 00 00 01 00 00
Feb 10 14:46:21 NAS Feb 10 14:46:21 NAS (0:4:0/0): Tag: 0x16300f3, type 1
Feb 10 14:46:21 NAS Feb 10 14:46:21 NAS (1:4:0/0): COMPARE AND WRITE. CDB: 89 00 00 00 00 00 00 00 a9 b8 00 00 00 01 00 00
Feb 10 14:46:21 NAS Feb 10 14:46:21 NAS (0:4:0/0): WRITE(10). CDB: 2a 00 09 ac 90 b0 00 00 08 00
