problems with Pool I/O error
exelzur
Ive got a Problem, sry for my Bad English ( German )
Today my Freenas Server 9.3.1 Dies: mfi0 I/O error and one or more Devices are not available cannot import.
Asus Board with 12 GB ram
Raid Controller perc h310
WD Green Disks
2 Seagate Disks
1 SSD
I Testet some NFS Shares with 2 VMs and it stocked an I resettet the Freenas Server "hard"
What can i Do got i any chances?
some logs :
http://pastebin.com/HfALxfEK
1.[root@ark1 ~]# zpool status
2.  pool: freenas-boot
3.state: ONLINE
4.  scan: scrub repaired 0 in 0h5m with 0 errors on Sat Nov  7 03:50:13 2015
5.config:
6.
7.        NAME        STATE     READ WRITE CKSUM
8.        freenas-boot  ONLINE       0     0     0
9.          ada0p2    ONLINE       0     0     0
10.
11.errors: No known data errors
12.[root@ark1 ~]#
exelzur
Critical: The volume Pool1 (ZFS) state is UNKNOWN:
zpool Import:
[root@ark1 ~]# zpool import
   pool: Pool1
  state: ONLINE
action: The pool can be imported using its name or numeric identifier.
        Pool1                                           ONLINE
          raidz2-0                                      ONLINE
            gptid/fe6f637a-3f86-11e4-a0a3-ac220bc7a8dc  ONLINE
            gptid/ff075b02-3f86-11e4-a0a3-ac220bc7a8dc  ONLINE
            gptid/ffa491e1-3f86-11e4-a0a3-ac220bc7a8dc  ONLINE
            gptid/0046c681-3f87-11e4-a0a3-ac220bc7a8dc  ONLINE
            gptid/00ac83ea-3f87-11e4-a0a3-ac220bc7a8dc  ONLINE
            gptid/012da711-3f87-11e4-a0a3-ac220bc7a8dc  ONLINE
          mirror-1                                      ONLINE
            gptid/01a9b043-3f87-11e4-a0a3-ac220bc7a8dc  ONLINE
            gptid/021e37ad-3f87-11e4-a0a3-ac220bc7a8dc  ONLINE
        cache
          gptid/2fa44cfe-2895-11e5-ad8b-ac220bc7a8dc
[root@ark1 ~]#
Robert Trevellyan
Pony Wrangler
I see you've posted the same issue in the German forum. It appears someone is trying to help you there, but has noted that you're using a RAID controller, which can cause problems.
Is the volume available for import in the GUI?
exelzur
Yes i Tryed it Both german and here, Yes a Perc H310 but no Aktive Raid only to Connect the Drives.
Yes i looked at import but 2 TB is missing i think the mirror.
Should i Import what is possible?
Robert Trevellyan
Pony Wrangler
Is the H310 flashed to IT mode? If not, it could be trouble, either now or later.
Maybe the GUI doesn't like to import a pool with mismatched vdevs. I would probably try the import from the CLI.
exelzur
No not Flashed. I asked for a While if it some difference between the Raid and nonraid Firmware. But nobody know this...
i hope tomoworrow a flashed m1015 arraives me. i Connect it and could test a import?!
exelzur
thats the output :
[root@ark1 ~]# zpool import -R /mnt Pool1
cannot import 'Pool1': one or more devices is currently unavailable
[root@ark1 ~]#
or:
[root@ark1 ~]# zpool import -o readonly=on -R /mnt Pool1
[root@ark1 ~]#
and this error :
Nov 14 19:18:32 ark1 mfi0: 13626 (500840312s/0x0002/info) - Unexpected sense: PD 00(e0xff/s0) Path 4433221107000000, CDB: 28 00 43 85 6c 00 00 01 00 00, Sense: 3/11/00
Nov 14 19:18:32 ark1 mfi0: I/O error, cmd=0xfffffe00007bc550, status=0x2d, scsi_status=0x2
Nov 14 19:18:32 ark1 mfi0: sense error 112, sense_key 3, asc 17, ascq 0
Nov 14 19:18:32 ark1 mfisyspd0: hard error cmd=read 1132817408-1132817663
Robert Trevellyan
Pony Wrangler
Does the output from zpool import that you posted in #3 above show all the devices that you expect to see?
exelzur
Yep the Raidz2 is about wd Green Drives 2 TB , The Mirror is about 2 1 tb Drives from Seagate and the cache is a ssd
exelzur
Got this with the M1015
New Log : http://pastebin.com/yW7FMucx
zpool status
  pool: freenas-boot
state: ONLINE
          ada0p2    ONLINE       0     0     0
[root@ark1 ~]# ^C
[root@ark1 ~]#
zpool import and zpool import Pool1:
   pool: Pool1
  state: ONLINE
        Pool1                                           ONLINE
          raidz2-0                                      ONLINE
          mirror-1                                      ONLINE
        cache
[root@ark1 ~]# zpool import Pool1
Please help me to recover my data :(
Robert Trevellyan
Pony Wrangler
OK, I finally see the elephant in the room. ZFS thinks the cache device is missing, though that may not be the real issue. You are in deep trouble unless you can restore from backup. See this thread. Unfortunately I don't have a solution for you.
exelzur
All is okay in the German Part they give mehr the advise to Pull out the da 7 Device and Freundschaft degraded the Pool and I can Access the Data.
The nett Step is to Backup the Data. How could i geh out the Cache and the Mirror?
I only want one big raidz2
