I share two datasets without problems with my Freenas, one http and the other https on 3 different devices and each one does one thing to me.
1st Android
both http and https are perfect and I can upload and download files at full speed.
2nd Windows 7
I can only access the http and the access is very slow, I have installed the cyberduck and it is better but accessing the https is impossible (it asks me to install certificates).
3rd Windows 10
I only access http which is going at a very good speed but my surprise is that I can copy the files from the server to the pc but the other way around from the pc to the server it gives me an error and it keeps a file with the same name with 0 bytes. It tells me that it cannot access the disk. I would like to know why, as you can see, I have deactivated the firewall and other Windows security options.
In both w7 and 10 I can access https through chrome without problems, but if I try to connect as a network or file drive it tells me that it cannot be found.
Above all I would like to know the reason for the problem of windows 10.
Thank you
1st Android
2nd Windows 7
3rd Windows 10
Thank you
