Henning Kessler
- Feb 10, 2015
Hi there,
if have setup a AD domain with samba and after binding successfully two Macs to it I tried to bind a FreeNAS server (11.1-U6) to it as well. Unfortunately it fails to bind every time I try.
The first reason was that samba rejected a simple bind so I imported the samba CA, the key and the cert into FreeNAS and selected TLS as encryption and the imported certificate in the setup. That solved the issue with that error but binding still failed.
Here is the output of the commands from the FreeNAS guide Chapter 9.1.2. Mayba someone can give me a hint...
root@FreeNAS[13:39][~]: sqlite3 /data/freenas-v1.db "update directoryservice_activedirectory set ad_enable=1;" root@FreeNAS[13:54][~]: echo $? 0 root@FreeNAS[13:54][~]: service ix-kerberos start root@FreeNAS[13:54][~]: service ix-nsswitch start root@FreeNAS[13:54][~]: service ix-kinit start root@FreeNAS[13:55][~]: service ix-kinit status root@FreeNAS[13:55][~]: echo $? 0 root@FreeNAS[13:55][~]: klist Credentials cache: FILE:/tmp/krb5cc_0 Principal: administrator@INT.SOMEWHERE.DE Issued Expires Principal Oct 5 13:55:07 2018 Oct 5 23:55:07 2018 krbtgt/INT.SOMEWHERE.DE@INT.SOMEWHERE.DE root@FreeNAS[13:55][~]: python /usr/local/www/freenasUI/middleware/notifier.py start cifs True root@FreeNAS[13:55][~]: service ix-activedirectory start Join to domain is not valid: NT code 0xfffffff6 Failed to join domain: failed to connect to AD: Cannot read password False winbindd not running? (check /var/run/samba4/winbindd.pid). smbd not running? (check /var/run/samba4/smbd.pid). nmbd not running? (check /var/run/samba4/nmbd.pid). True root@FreeNAS[13:56][~]: service ix-activedirectory status root@FreeNAS[13:56][~]: echo $? 1 root@FreeNAS[13:57][~]: python /usr/local/www/freenasUI/middleware/notifier.py restart cifs True root@FreeNAS[13:57][~]: service ix-pam start root@FreeNAS[13:58][~]: service ix-cache start & [1] 37195
