SOLVED Problems activating mrsas on H310 IT
ntrp
Hello, I have a Dell PERC H310 flashed in IT mode. The 8 * 4TB IronWolf disks are recognized and the zpool is working properly but I get no S.M.A.R.T. info and the Dashboard UI crashes because of that..
The driver being loaded is the mfis one and I tried everything to force mrsas by setting the recomended hints but it did not work. I have although /dev/passX devices that allow S.M.A.R.T. readings and after setting mfis passthrough using the cam property I have seen duplicated disks (/dev/daX and /dev/mfisyspdX) but still broken monitoring.
Some debug:
% sudo mfiutil show adapter
mfi0 Adapter:
    Product Name: PERC H310 Adapter
   Serial Number: 46J008N
        Firmware: 20.12.1-0002
     RAID Levels: JBOD, RAID0, RAID1, RAID5, RAID10, RAID50
  Battery Backup: not present
           NVRAM: 32K
  Onboard Memory: 0M
  Minimum Stripe: 64K
  Maximum Stripe: 64K
% sudo mfiutil show firmware
mfi0 Firmware Package Version: 20.12.1-0002
mfi0 Firmware Images:
Name  Version                        Date         Time         Status
BIOS  4.34.00_4.12.05.00_0x05260000  12/10/2012
  12/10/2012
  active
PCLI  03.02-015:#%00008              Oct 12 2010  14:13:05     active
CTLR  3.00-0022                      Nov 29 2012  21:27:42     active
NVDT  3.09.03-0038                   May 25 2012  16:49:53     active
APP   2.120.14-2657                  Jul 22 2013  15:29:43     active
BTBL  2.02.00.00-0001                Aug 18 2010  11:44:44     active
% sudo mfiutil show drives
mfi0 Physical Drives:
0 ( 3726G) JBOD <ST4000VN008-2DR1 SC60 serial=ZGY3TF71> SATA S0
1 ( 3726G) JBOD <ST4000VN008-2DR1 SC60 serial=ZGY3TJ2A> SATA S1
2 ( 3726G) JBOD <ST4000VN008-2DR1 SC60 serial=ZGY3THH3> SATA S2
3 ( 3726G) JBOD <ST4000VN008-2DR1 SC60 serial=ZGY3TGWQ> SATA S3
4 ( 3726G) JBOD <ST4000VN008-2DR1 SC60 serial=ZGY3THRY> SATA S4
5 ( 3726G) JBOD <ST4000VN008-2DR1 SC60 serial=ZGY3THFP> SATA S5
6 ( 3726G) JBOD <ST4000VN008-2DR1 SC60 serial=ZGY3THW2> SATA S6
7 ( 3726G) JBOD <ST4000VN008-2DR1 SC60 serial=ZGY3TEZA> SATA S7
% sudo pciconf -lvcb mfi0
mfi0@pci0:4:0:0:        class=0x010400 card=0x1f4e1028 chip=0x00731000 rev=0x03 hdr=0x00
    vendor     = 'LSI Logic / Symbios Logic'
    device     = 'MegaRAID SAS 2008 [Falcon]'
    class      = mass storage
    subclass   = RAID
    bar   [10] = type I/O Port, range 32, base 0xe000, size 256, enabled
    bar   [14] = type Memory, range 64, base 0xfb160000, size 16384, enabled
    bar   [1c] = type Memory, range 64, base 0xfb100000, size 262144, enabled
    cap 01[50] = powerspec 3  supports D0 D1 D2 D3  current D0
    cap 10[68] = PCI-Express 2 endpoint max data 256(4096) FLR NS
                 link x8(x8) speed 5.0(5.0) ASPM disabled(L0s)
    cap 03[d0] = VPD
    cap 05[a8] = MSI supports 1 message, 64 bit enabled with 1 message
    cap 11[c0] = MSI-X supports 15 messages
                 Table in map 0x14[0x2000], PBA in map 0x14[0x3800]
    ecap 0001[100] = AER 1 0 fatal 0 non-fatal 1 corrected
    ecap 0004[138] = Power Budgeting 1
Anybody has a clue on what should I do?
EDIT: Just after posting I found this /index.php?threads/confused-about-that-lsi-card-join-the-crowd.11901. Could it be that it's not properly flashed? Is there a solution?
Chris Moore
ntrp
Thanks, I just actually realized it is not properly flashed as I erroneously assumed by seeing single disks in linux.. I will check out the tutorial and flash it.
ntrp
Ok seems like now the disks are correctly recognized and they are using the msp driver. Still have some UI and performance quirks but I will research on them first.
As a reference for anybody finding this post I used this tutorial:
https://techmattr.wordpress.com/201...r-flashing-to-it-mode-dell-perc-h200-and-h310
p.s. I kinda feel stupid after wasting so much time on it (even trying it for days in Xpenology) just because I assumed was already flashed..
