si, ya vi ese post esta mañana, pero ya te digo en el paso 2 no me aparece ningun volumen...
Los volumenes eran ZFS y la version era 9.2, la ultima estable ya que lo monte hace 1 mes o asi...
lo mas parecido a un error cuando he puesto ese comando ha sido:
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. ioapic0 <Version 2.1> irqs 0-23 on motherboard kbd1 at kbdmux0 cryptosoft0: <software crypto> on motherboard padlock0: No ACE support.
acpi0: <HP ProLiant> on motherboard acpi0: Power Button (fixed)
acpi0: reservation of fee00000, 1000 (3) failed
acpi0: reservation of ffb80000, 80000 (3) failed
acpi0: reservation of fec10000, 20 (3) failed
acpi0: reservation of fed80000, 1000 (3) failed
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, d7f00000 (3) failed
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
y la parte de los discos duros:
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD30EFRX-68EUZN0 80.00A80> ATA-9 SATA 3.x device
ada0: Serial Number WD-WMC4N1248544
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled ada0: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K> ada0: Previously was known as ad4 ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <WDC WD30EFRX-68EUZN0 80.00A80> ATA-9 SATA 3.x device ada1: Serial Number WD-WMC4N1156937
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada1: quirks=0x1<4K>
ada1: Previously was known as ad6
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <WDC WD30EFRX-68EUZN0 80.00A80> ATA-9 SATA 3.x device ada2: Serial Number WD-WMC4N1213099
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada2: quirks=0x1<4K>
ada0: Serial Number WD-WMC4N1248544 ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Previously was known asad4 ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: quirks=0x1<4K> ada1: Previously was known as ad6
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0 ada2: <WDC WD30EFRX-68EUZN0 80.00A80> ATA-9 SATA 3.x device ada2: Serial Number WD-WMC4N1213099
ada2: Command Queueing enabled ada2: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
device_attach: uhid0 attach returned 12 Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]... GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
GEOM_ELI: Device ada0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI: Crypto: software GEOM_ELI: Device ada1p1.eli created.
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: Device ada3p1.eli created.
GEOM_ELI: Crypto: software arp: 192.168.0.2 moved from 00:50:56:87:29:8f to fc:99:47:1b:3c:c7 on bge0 arp: 192.168.0.2 moved from fc:99:47:1b:3c:c7 to fc:99:47:1b:3c:c6 on bge0 arp: 192.168.0.2 moved from fc:99:47:1b:3c:c6 to 00:50:56:87:29:8f on bge0
ZFS NOTICE: Prefetch is disabled by default on i386 -- to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
ZFS WARNING: Recommended minimum kmem_size is 512MB; expect unstable behavior. Consider tuning vm.kmem_size and vm.kmem_size_max
in /boot/loader.conf.
ZFS filesystem version: 5
ZFS storage pool version: features support (5000) arp: 192.168.0.2 moved from 00:50:56:87:29:8f to fc:99:47:1b:3c:c0 on bge0 arp: 192.168.0.2 moved from fc:99:47:1b:3c:c0 to 00:50:56:87:29:8f on bge0 arp: 192.168.0.2 moved from 00:50:56:87:29:8f to fc:99:47:1b:3c:c0 on bge0 arp: 192.168.0.2 moved from fc:99:47:1b:3c:c0 to 00:50:56:87:29:8f on bge0 (END)
Saludos y gracias de nuevo!!
