Problem with wiping disk in FreeNAS 11 - asc:81,0 (Vendor Specific ASC)
Vidis
I have a Dell 720xd server with a 16 slot 2.5" disc backplane connected to a PCIe LSI SAS 9207-8i.
I have bought 16 disks off of ebay that I have placed in the server.
The LSI card can see the disk just fine and everything looks ok.
However when I try and create a volume or wipe the disk I get the following errors
Software Version: FreeNAS-11.1-RELEASE (dc7d195f4)
Exception Type: MiddlewareError
Exception Value:
[MiddlewareError: Failed to wipe da0: dd: /dev/da0: Input/output error
1+0 records in
0+0 records out
0 bytes transferred in 0.042045 secs (0 bytes/sec)
On the console and in the /var/log/messages file I can see the following errors also.
Jan  4 03:32:00 SEKBA-FNAS-01 notifier: gpart: Device not configured
Jan  4 03:32:00 SEKBA-FNAS-01 (da0:mps0:0:8:0): WRITE(6). CDB: 0a 00 00 00 01 00
Jan  4 03:32:00 SEKBA-FNAS-01 (da0:mps0:0:8:0): CAM status: SCSI Status Error
Jan  4 03:32:00 SEKBA-FNAS-01 (da0:mps0:0:8:0): SCSI status: Check Condition
Jan  4 03:32:00 SEKBA-FNAS-01 (da0:mps0:0:8:0): SCSI sense: ABORTED COMMAND asc:81,0 (Vendor Specific ASC)
Jan  4 03:32:00 SEKBA-FNAS-01 (da0:mps0:0:8:0): Command Specific Info: 0x1800
Jan  4 03:32:00 SEKBA-FNAS-01 (da0:mps0:0:8:0): Retrying command (per sense data)
Jan  4 03:32:01 SEKBA-FNAS-01 notifier: gpart: Input/output error
Jan  4 03:32:01 SEKBA-FNAS-01 (da0:mps0:0:8:0): WRITE(6). CDB: 0a 00 00 00 01 00
Jan  4 03:32:01 SEKBA-FNAS-01 (da0:mps0:0:8:0): CAM status: SCSI Status Error
Jan  4 03:32:01 SEKBA-FNAS-01 (da0:mps0:0:8:0): SCSI status: Check Condition
Jan  4 03:32:01 SEKBA-FNAS-01 (da0:mps0:0:8:0): SCSI sense: ABORTED COMMAND asc:81,0 (Vendor Specific ASC)
Jan  4 03:32:01 SEKBA-FNAS-01 (da0:mps0:0:8:0): Command Specific Info: 0x1800
Jan  4 03:32:01 SEKBA-FNAS-01 (da0:mps0:0:8:0): Retrying command (per sense data)
Jan  4 03:32:01 SEKBA-FNAS-01 (da0:mps0:0:8:0): Error 5, Retries exhausted
Jan  4 03:32:01 SEKBA-FNAS-01 uwsgi: [middleware.exceptions:36] [MiddlewareError: Failed to wipe da0: dd: /dev/da0: Input/output error
1+0 records in
0+0 records out
Jan  4 03:32:01 SEKBA-FNAS-01 (da0:mps0:0:8:0): WRITE(10). CDB: 2a 00 00 00 00 00 00 01 00 00
Jan  4 03:32:01 SEKBA-FNAS-01 uwsgi: [storage.views:907] Could not check for disk wipe progress: [Errno 3] No such process
Does anyone have any clue on why this is happening or what can be done to fix it?
Nick2253
Bad drive?
Have you checked all your hard drives? Run SMART tests? Etc. There's a post somewhere around here with advice for doing HDD checks.
wblock
Documentation Engineer
Please show the output of diskinfo -v da0 inside [code] and [/code] tags.
Vidis
Wow this will be a really long time since my last post on this. I had to put this on hold due to life stuff.
I have now picked this up again an I have run the command that you asked me to do and this is the result.
I ran it on my first 3 drives. I have a total of 13 drives that all are failing.
My guess is that this is due to the firmware on the disks that are causing my grief.
Any help is really appropriated.
root@freenas:/var/log #  diskinfo -v da0
da0
		512			 # sectorsize
		600127266816	# mediasize in bytes (559G)
		1172123568	  # mediasize in sectors
		0			   # stripesize
		0			   # stripeoffset
		72961		   # Cylinders according to firmware.
		255			 # Heads according to firmware.
		63			  # Sectors according to firmware.
		HITACHI DKR5C-J600SS	# Disk descr.
		PZG0BXVD				# Disk ident.
		Not_Zoned	   # Zone Mode
root@freenas:/var/log # diskinfo -v da1
da1
		512			 # sectorsize
		0			   # stripesize
		0			   # stripeoffset
		PVKJATND				# Disk ident.
root@freenas:/var/log # diskinfo -v da2
da2
		512			 # sectorsize
		0			   # stripesize
		0			   # stripeoffset
		PPW1EP5B				# Disk ident.
