SOLVED problem with VM server
hesseh
installed VM Ubunto 20.04.2 as a VM.
It is running and VNC is accessible... I have the server ip and I opened port 22...
but cannot do a sudo apt update: the VM server does not resolve the ip addresses...
cannot ping 8.8.8.8
VM server is accessible by built-in VNC but not by PUTTY
I did not install any proxy server... Is that the problem?
hesseh
fixed: made mistake in the setup installation: installed the open ssh package
also reinstalled not using the Virtio drivers
