markuslacht
- May 13, 2022
Hey there,
I have a reverse proxy setup using nginx for my server and it works I can access multiple local ip's with diffrent subdomains.
Now I installed a
ubuntu 20.04 server did ip a -> 192.168.178.58 (using the online vnc that perfectly works), whoami -> markus, sudo ufw allow ssh, (checked that sshd is running)
enabled ssh service
NOW I want SSH access from external (not same LAN network)
1) How do I have to configure my reverse proxy / nginx service that runs in a sperate jail?
2) Any port I have to use 5800?, 5900?
3) Any special adjustments of my NIC of my VM?
I tried this but it does not work:
ssh markus@virtual.xxxx.de -> Doing that I can only access my truenas server but not the VM
ssh markus@192.168.178.58 -> worked when I am in the same LAN.
Now I installed a
enabled ssh service
server { listen 80; listen 443 ssl; server_name virtual.xxxx.de; ssl_certificate /usr/local/etc/letsencrypt/live/sv.simact.de/fullchain.pem; location / { proxy_pass http://192.168.178.58; } error_page 500 502 503 504 /50x.html; location = /50x.html { root /usr/local/www/nginx-dist; } }
