problem with the consumption of RAM
Astro1234
good afternoon everyone
I have a question because there is something that I do not understand, on the main page when I load the main page of my NAS with SO FREENAS 11.2 I see that the RAM consumption meter always goes up in memory consumption and without executing anything in the NAS
is that normal or not?
if it is not as I see what is generating the expense
or is it just a measurement error
garm
Unused RAM is wasted money, ZFS will fill it with useful things
G8One2
Your up time is only barely over 1 day. Over time, it will use up all available RAM through ARC, but it takes a few days or longer, depending on usage. The system hasn't been up long enough to use up RAM. Give it some time.
Chris Moore
Your FreeNAS system uses a file system called ZFS and ZFS uses RAM for cache of file operations. Your system should fill all but about 2GB of available memory with ARC (Adptive Replacement Cache) data and that is normal. It is meant to make the NAS more responsive by keeping frequently used information in memory.
Astro1234
ok perfect then it is normal to go up to 32 GB of RAM.
I'm going to leave it like this thanks.
another question there is no power saving mode for PC to suspend when not in use
G8One2
You want to keep your FreeNas running 247. Its not meant to be powered on and off.
Chris Moore
It is not the default mode for a NAS to suspend because it has no way of knowing when it might be accessed again over the network.
Chris Moore
Thank you very much everyone for the explanation is that I am totally new using FREENAS
If you take a look at the "Useful Links" in my signature, there is a lot of reading there that will help you learn more about FreeNAS and ZFS.
Astro1234
OK thanks for everything
now to configure the download server a question i'm seeing that there are two services to be able to do it
transmission
qbittorrent
which one is the best I hear suggestions
