D
Deleted member 86555
Guest
I have a newly installed FreeNAS-11.1-U5, because the usb drive died. The pervious usb was running was running FreeNAS-11.1-U4 and i didn't have this problem then. The problem is that networking doesn't work in my one and only vm, but it's only outbound that's not working. I can reach the vm over ssh and also ping it but i can not access the internet or any computer on the local network from the vm.
My freenas networking setup looks like this:
em0(igb0) < -- connected to lan subnet. ip from dhcp:192.168.1.188
em1(igb1) < -- connected to dmz subnet. has no ip but have tried with ip. subnet:192.168.2.0
bridge0 < -- bridge bettwen igb1 and tap0
tap0 < -- vm
I am relatively sure it's not a problem in the client vm's os because i have check the default rout and also booted in to a live-cd and tried to setup the network there with the same result. Which leads me to believe that the problem is in the setup of the interfaces on the freenas, all of the setup was done in the webui.
This is from freenas:
tap0 < -- vm
netstat -rnCode:
Routing tables Internet: Destination Gateway Flags Netif Expire default 192.168.1.254 UGS igb0 127.0.0.1 link#3 UH lo0 192.168.1.0/24 link#1 U igb0 192.168.1.188 link#1 UHS lo0 Internet6: Destination Gateway Flags Netif Expire ::/96 ::1 UGRS lo0 ::1 link#3 UH lo0 ::ffff:0.0.0.0/96 ::1 UGRS lo0 fe80::/10 ::1 UGRS lo0 fe80::%lo0/64 link#3 U lo0 fe80::1%lo0 link#3 UHS lo0 ff02::/16 ::1 UGRS lo0
ifconfigCode:
igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6> ether d0:50:99:c1:88:6b hwaddr d0:50:99:c1:88:6b inet 192.168.1.188 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (100baseTX <full-duplex>) status: active igb1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6> ether d0:50:99:c1:88:6c hwaddr d0:50:99:c1:88:6c nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:3b:59:e7:eb:00 nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 4 priority 128 path cost 2000000 member: igb1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 2 priority 128 path cost 20000 tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=80000<LINKSTATE> ether 00:bd:18:6c:42:00 hwaddr 00:bd:18:6c:42:00 nd6 options=1<PERFORMNUD> media: Ethernet autoselect status: active groups: tap Opened by PID 33022
