I have a challenge to set the permission correct for my Media Dataset. The set-up is as follows
I AM NOT ABLE TO GET THE INHERIT TO WORK. HOW CAN I ACHIVE THIS?
- I am running Radarr, Soanrr, Zabnzbd as Apps in TrueNas Scale
- A Media dataset is mounted under a media folder in each application offering added space and access to the Media dataset from each application
- The TruenNas system is joined to a Microsoft AD making it possible for all AD users to access the TrueNAs system
- The apps run under the user: apps and in group: apps
- The Media dataset is set up as a SMB share for external access for the network
- I want the following permissions and ownerships from Media and for all sub datasets and directories. (This is easily set up by use of the ACL editor)
- Owner: apps Group: apps (full control)
- Everyone (Read access)
- AD_user1 (Full control)
- AD_group1 (FTP read)
- AD_group2 (RD Access)
- When Sonarr/Radarr download files they are first downloaded then renamed and moved to a directory under Media. So specific directories are created with sub directories if need under this. Even if the father directory (all the way up to Media) has the right permissions and the inherit is set to ON, the resulting owner of the directories and files is apps:apps with Everyone with read rights
