Problem to add disk partition (physical) in Vmware FreeNAS guest
14Chris
I have a problem with my Freenas virtual machine (Vmware workstation 14 on Linux).
When I want to add a physical partition to my Freenas vm, I have the entire disk instead of one partition.
Someone had the same problem ?
Chris
physical partition
I think this may be your problem... a partition is logical, not physical... disks are physical.
If you're just using it for testing, it may be OK to create a virtual disk in VMware and add it to the VM, but if this is a serious use of FreeNAS, use caution as not passing through at the (entire) controller level is dangerous.
14Chris
The problem is that if it's for exampl a vm with linux as guest it will work if I choose to add a host partition as a hard drive for the vm. With Freenas this deosn't work correctly ...
kdragon75
What is your intended use of the FreeNAS VM?
kdragon75
I want to use it for access file over smb, ssh and to backup all my datas
I cannot help you as this will almost certainly end badly for you and your data.
