Problem setting up volume
JournaL
I am very new to this, I just built and installed my freenas system today but I am having an issue with creating a volume (both thru the wizard or manually by clicking on the volume tab). I have three 6TB drives (new and ready to go). The Bios and Freenas detects it as ada0, ada1, ada2. Freenas is installed onto a flash drive I think adop2.
After I boot, I try to go in and create a volume, freenas sees all three drives and I name it and set it to ZFS1 and when I click Create Volume it gives me this error: Error: Unable to GPT format the disk "ada0" .
Then I check the drives again, and this time ada0 disappears, and only ada1 and ada2 are visible. I reboot the system and all three drives are visible again, but when I try to create a volume again, the same error.
I verified my installation and I am not sure whats going on. I tried looking this issue up but I am not sure what to do. Can you please help me?
JournaL
I also tried rebooting and wiping the ada0 disk but I get this error
Error: Failed to wipe ada0: dd: /dev/ada0: Input/output error 1+0 records in 0+0 records out 0 bytes transferred in 0.626794 secs (0 bytes/sec)
My freenas says
CAM Status Uncorrectable Parity Error/CRC error on the ada0 drive.
So is the drive bad?
SweetAndLow
Sweet'NASty
Please list your hardware specs like the forum rules state.
JournaL
Please see my signature for hardware information
jgreco
Resident Grinch
My freenas says
Let's say it isn't a promising sign. Pull up the Hitachi Drive Fitness Test and see what it says.
If the disk is bad, and it is still within its return window, return it for a refund, not a replacement. Then buy a separate replacement. This sometimes avoids a scenario where a vendor might send you a refurb drive.
JournaL
Turns out linkdepot Sata cables are crap. Real Crap. No errors now after switching out both of the link depot cables I tried to test with one from a older SATA2 Mobo
