Problem logging in
DjBac
For the past two weeks for a long period during the day I cannot login through the gui, ssh nor afp.
All the jails work fine.
Attached find the gui result after logging in!
Any help on this? ;)
rm-r
try using firefox
DjBac
Already tried that with no results.
But I have the problem with ssh and afp too.
You should check your network configuration. Likely something is wrong. Try pinging the box. If you don't get a response to ping then you have problems.
rm-r
do you have an intel nic? or reltek?
sounds similar to my issues until i switched to intel nics
DjBac
I can ping the box just fine!!
I have intel nics, both of them.. This problem only started to happen in the past few weeks.
rm-r
try using a new USB with fresh install of freenas
rm-r
thats the gui saying it cant get to the freenas webui specific parts for the pluins (your NAS ip will be x.x.1.11 right)
have you set a default gateway in the network >> global tab?
