TinyWorkshop
- Jul 14, 2022
Lately I'm having a lot of problems installing apps,
For example, I'm trying to install navidrome on my scale 23.10.2:
I get this error more or less If I try to install any other new app
Already installed apps works fine and update without issues
any idea????
2024-03-13 10:08:45 Failed to pull image "deluan/navidrome:0.51.1": rpc error: code = Unknown desc = failed to pull and unpack image "docker.io/deluan/navidrome:0.51.1": failed to copy: httpReadSeeker: failed open: unexpected status code https://registry-1.docker.io/v2/deluan/navidrome/manifests/sha256:ea426987cc4a148eb6a9fcea60ab44cc0dca4d7f0f1e12a4b48f5937454da4d9: 429 Too Many Requests - Server message: toomanyrequests: You have reached your pull rate limit. You may increase the limit by authenticating and upgrading: https://www.docker.com/increase-rate-limit 2024-03-13 10:08:45 Error: ErrImagePull 2024-03-13 10:08:40 Pulling image "deluan/navidrome:0.51.1" 2024-03-13 10:08:37 Created container navidrome-install-01-permissions 2024-03-13 10:08:37 Started container navidrome-install-01-permissions 2024-03-13 10:08:36 Scaled up replica set navidrome-f88c7bb96 to 1 2024-03-13 10:08:36 Created pod: navidrome-f88c7bb96-gb5c7 2024-03-13 10:08:36 Successfully assigned ix-navidrome/navidrome-f88c7bb96-gb5c7 to ix-truenas 2024-03-13 10:08:36 Add eth0 [172.16.3.221/16] from ix-net 2024-03-13 10:08:36 Container image "bash:4.4.23" already present on machine
any idea????
