SOLVED Problem creating iSCSI target
Eric Gaberik
Hey there, brand new to this forum as well as brand new to FreeNAS. I have a server that is running FreeNAS with an Adaptec 6445 RAID controller with three RAID 5 Virtual Drives built on it. FreeNAS is able to see those devices and I am trying to set those up as iSCSI targets that a few ESXi 5.5 initiators can point to. I think I have configured everything correctly but when I go to start the iSCSI service I get a message that says it was unable to start the service . I have attached my info from /var/log/messages.
I can add more configuration details if needed. Appreciate the help!
D
dlavigne
Guest
Which version of FreeNAS (full "Build" name from System Information)?
Eric Gaberik
FreeNAS-9.2.1.9-RELEASE-x64 (2bbba09)
Also worth noting that with my extents associated to my target is when I get this error. If I take them out of my associated targets I can start the iSCSI service. Not sure if this would help pinpoint my issue.
D
dlavigne
Guest
There was one ctl bug that was fixed after release so if there are any available updates, apply them.
If that doesn't fix the issue, it may be a different one. In that case, create a bug report at bugs.freenas.org indicating the condition under which the error occurs and post the issue number here.
Eric Gaberik
I am working on getting this done I will update the thread appropriately when I get results.
Thanks for the help.
