I had a brief power outage this morning and my Freenas server did not come back up. The console should the db> output and would not do anything else. I did a fresh install of the Freenas 9.2.0 x86 and got it to boot and was able to successfully import one of my zfs pools labeled Movies. My other pool labeled Data will not import. It shows up as available when I try to do the auto import volume in the gui but errors out and just puts a bunch of text across the console before it reboots. It is a Dell XPS 400 with 4GB of RAM two 500GB drives and 2 3TB drives. When I run zpool status the Movie pool shows up as it is supposed too but not the Data. I have run zpool import and this is the output. If I need to recreate the pool that is fine but how do I retrieve the data off of here. It is a mirrored zfs pool. Thanks for your help in advance.
[root@freenas ~]# zpool import
pool: Data
state: ONLINE
action: The pool can be imported using its name or numeric identifier.
Data ONLINE
mirror-0 ONLINE
gptid/94edaf2a-89b6-11e3-a916-0013721ca27a ONLINE
gptid/956a70cd-89b6-11e3-a916-0013721ca27a ONLINE
pool: Data
state: ONLINE
Data ONLINE
mirror-0 ONLINE
