I have a HP server with a HP Smart Array P800 Controller card which does not do pass-through. As such I am either stuck with creating Raid0 logical drives for each physical drive, or using the hardware Raid and losing out on being able to use ZFS.
If I were to want to keep ZFS around, then I will need a way to replace a failed drive, which will either involve rebooting to get into the controllers configuration, or using http://www.freshports.org/sysutils/hpacucli/
My question is, since the plugins run in a jail, is the hpaculcli even a candidate for a plugin? Will it have access to the hardware? I don't want to have to re-boot the server in the case of a hardware failure.
