possible to revert to core 13u4 from scale?
Vertigo 7
if I've backed up my core config, is there any reason I can't revert to core by formatting the boot pool and reinstalling/restoring from backup? There are some thing I want to look at in scale but I don't want to attempt the migration if I'm screwed because expectations of scale don't meet capability. My data pools are all whatever the current ZFS revision is for core 13u4.
Why wouldn't you just boot back to the core boot environment?
Just make sure you avoid the temptation to upgrade pools while in SCALE.
Well, now you made me test it...
When I upgrade a test VM, I see the boot menu starts with 2 items: TrueNAS SCALE (default) and TrueNAS CORE.
The GRUB boot menu comes after that.
And when booted into SCALE, I can go to the boot menu and select the old CORE boot environment and activate it... then reboot...
And there I have it: CORE.
Vertigo 7
right i see the same as well but i recall reading some other posts that core fails to boot after grub is updated with scale.
As edited above, tested with success... upgrade, set boot environment back, reboot, CORE works.
I did/could not test further upgrading SCALE after the initial upgrade, so maybe the reports you're talking about refer to that somehow wiping out the initial rollback option after a subsequent upgrade to SCALE, but I'm not sure how that would look as it seems SCALE operates behind that initial boot selector.
Vertigo 7
well hopefully i don't have to roll back. trying to get around some of the frankly dumb networking limitations in docker...
Best of luck with it.
