panzerscope
- May 30, 2022
Hello all,
I am noticing some strange behaviour regarding my NIC in TrueNas Core 13.
My NIC is the Intel X540 T2. I decided yesterday that I would make use of the second port on the NIC. However after it was setup, either via DHCP or Static, I noticed a couple of odd things.
1. Plex Streaming started to become jumpy or completely stop. Nothing had changed with Plex at all. Only change was the enabling of the second port on the NIC. Plex was still using port 1.
2. When shutting down or restarting TrueNas, it would hang when reaching the "Syncing Buffers" Stage. I left it for ages but nothing. However, as soon as a physically disconnected my LAN cable from port 2 on the NIC, the system shutdown. I was able to replicate this again, so it was not coincidental. So something regarding the second port on the NIC is causing the system to hang/do unexpected things.
Fortunately I had a second X540 T2 to test, thinking that just possibly I had a bad NIC. However we can throw that possibility out the window as with the replacement NIC, I get the exact same behaviour.
Still being new to the whole platform I am unsure how to retrieve any appropriate logs for looking at and to show you guys. Could someone give me a hand ?
Many thanks,
P
Many thanks,
P
