Doing some benchmarking on my newly built FreeNAS box, and trying to troubleshoot my TCP performance in iperf.
On default settings, I'm doing 0.3Gb/s max. Sometimes after a few minutes of benchmarking, it drops to ~.17Gb/s.
Hardware is as follows:
SuperMicro X58 w/ Dual Intel NICs
Intel i7-960
24GB of RAM
8*2TB Samsung drives in RAID-Z2
Cat5e cables between everything
Linksys E2000 (gigabit) <-Used to confirm gigabit connections
Cilents:
HP tablet laptop with gigabit connection
Desktop with i7-870, 8GB RAM, gigabit connection
I about 99.9% sure that hardware is not the problem because the speeds are the same between the laptop and desktop, and I just swapped motherboards in the FreeNAS system with no change in performance. As well as changing LAN ports on both motherboards, which makes me think it's a setting somewhere within FreeNAS.
My question is if there are settings in the TCP stack that can be edited to make this thing actually perform at gigabit speeds.
Intel i7-960
24GB of RAM
Cilents:
