Slow or not slow?
Gimmezell
I wanted to do my due diligence and gleaned as much information from various threads regarding slow performance before this post. One thing that I was able to resolve was slow speeds due to a cable between PC and router.
Prior to swapping out the cable and copying a 1GB video file from Windows 10 to a NAS share was transferring at 3-5MB/s. After, cable swap it transferred @11 MB/s
  • From my reading of various threads, even 11MB/s isn't all that great. However, it's certainly better than what I was getting before due to a bad cable. With my current hardware what should I be getting?
  • An area that is still slow is copying form one Dataset to another Dataset. I am getting about 5.5-6.5 MB/s. Is copying from Dataset to Dataset typically this slow?
Results from "openssl speed sha256"
type			 16 bytes	 64 bytes	256 bytes   1024 bytes   8192 bytes
sha256		   50807.28k   121393.18k   213088.69k   261813.46k   275362.08k
iperf results
Client connecting to 192.168.1.123, TCP port 5001
TCP window size: 63.0 KByte (default)
[  3] local 192.168.1.117 port 25252 connected with 192.168.1.123 port 5001
[ ID] Interval	   Transfer	 Bandwidth
[  3]  0.0-10.0 sec   110 MBytes  92.5 Mbits/sec
Only plugin I'm using us Plex.
FreeNAS 9.10.1
SUPERMICRO MBD-X10SLM+-F-O
Intel Core i3-4330
Crucial 16GB ECC
6 3TB WD RED drives RAIDZ-2
PC-->Asus RT-N66U-->TP Link 8-Port Gigabit switch
NAS--TP Link 8-Port Gigabit switch
Any help in getting my FreeNAS up to it's full potential would be great.
Thank you for taking the time to read this,
Jeremy
Clearly, there's still a 100Mb/s link in that path somewhere. Crap NIC on the client and/or bad cables are likely.
Gimmezell
Sounds like an easy fix. I will grab some extra cables from work this evening and swap some cables out.
Client (Windows 10 Pro): Intel I218-V (most recent driver)
Couple of other devices that are connected to the TP Link Gigabit swtich are only 100Mb/s capable (Xbox 360).
Newb question, can I assume if it lists "igb0" in Network Interfaces tab that FreeNAS is connected via 1Gb/s connection to the TP Link switch?
No. igb is the driver.
The switch should have an indicator of the link status, though.
Gimmezell
Well, apparently the TP-LINK TL-SG1008D Gigabit Desktop Switch does not have any link speed indication. How else can I tell the link speed?
SweetAndLow
Sweet'NASty
What color is the light for the port? Amber is 1000mbit/s and green is 100mbit/s. Something in your path is only working at 100mbit/s.
Gimmezell
Everything I have plugged in shows green. I unplugged my PC from my router and connected it to the switch. I do have a Gb/s connection that is confirmed via Windows Local Area Connection properties.
Update: I ran the ifconfig and the interface shows 1000baseT full duplex.
It is still slow copying from Dataset to Dataset, 3-5 MB/s.
SweetAndLow
Sweet'NASty
This is super easy to figure out and your ping test shows that you only have a 100mbit/s connection. Please describe everything in the networking path between freenas and your computer.
You can also direct connect your computer to freenas and eliminate the switch.
