Chris LaDuke
- Jan 17, 2014
I had posted in another thread and jgreco helped me determine why my SLOG was never being touched, it was because iSCSI default writes everything async and only sync writes get sent to the SLOG. So I changed my pool to sync=always. I then watched my performance plummet from 169MB/sec to consistent 105MB/sec and go from 2700 IOPS to 1660 IOPS. The benchmark is iostat 64k blocks 100% sequential write. my I am running my SLOG in a mirror or two Intel DCS 3700's. gstat shows them at about 65% busy when running iometer. I understand writing sync will be slower, but this seems really slow. I am not familiar enough to know what changes from an OS/zfs standpoint when writing sync that may cause other bottlenecks besides drive. Admittedly the gear is far from new, so I'm wondering CPU? Please let me know other tests I could run to help figure this out. Or, if this seems acceptable to those that know more than I, just let m know!
zpool status:
pool: FREENAS1
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
FREENAS1 ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/d2ab336e-8399-11e3-90e5-003048d5067c ONLINE 0 0 0
gptid/d31578b5-8399-11e3-90e5-003048d5067c ONLINE 0 0 0
mirror-1 ONLINE 0 0 0
gptid/eb375035-8399-11e3-90e5-003048d5067c ONLINE 0 0 0
gptid/ebabd762-8399-11e3-90e5-003048d5067c ONLINE 0 0 0
mirror-2 ONLINE 0 0 0
gptid/f4c37d34-8399-11e3-90e5-003048d5067c ONLINE 0 0 0
gptid/f52850fc-8399-11e3-90e5-003048d5067c ONLINE 0 0 0
logs
mirror-3 ONLINE 0 0 0
gptid/0b6f26b5-839a-11e3-90e5-003048d5067c ONLINE 0 0 0
gptid/0b99c5c1-839a-11e3-90e5-003048d5067c ONLINE 0 0 0
errors: No known data errors
Machine Specs:
Processor E5430 at 2.66 GHz
RAM: 12 GB
IO: IBM 1015 flashed to LSI-9211
(2) dual intel Gb server nics, each interface on its on VLAN
Drives: (6) 15k SAS 300GB in 3 mirrored pools
(2) Intel DC S3700 drives in a mirrored pool for SLOG
Each network interface was pushing about 350 mbit/sec and now is about 200 mbit/sec
Since the only thing I changed was on the ZFS side, seems like a FreeNAS/server issue.
Based on iozone the spool seems blazing fast.
output of iozone -s100M -r64K -I -t32 -T -i0 -i2
Record Size 64 KB
O_DIRECT feature enabled
Command line used: iozone -s100M -r64K -I -t32 -T -i0 -i2
Output is in Kbytes/sec
Time Resolution = 0.000001 seconds.
Processor cache size set to 1024 Kbytes.
Processor cache line size set to 32 bytes.
File stride size set to 17 * record size.
Throughput test with 32 threads
Each thread writes a 102400 Kbyte file in 64 Kbyte records
Children see throughput for 32 initial writers = 573816.64 KB/sec
Parent sees throughput for 32 initial writers = 175807.93 KB/sec
Min throughput per thread = 12081.14 KB/sec
Max throughput per thread = 27432.43 KB/sec
Avg throughput per thread = 17931.77 KB/sec
Min xfer = 43712.00 KB
Children see throughput for 32 rewriters = 3860336.24 KB/sec
Parent sees throughput for 32 rewriters = 199144.62 KB/sec
Min throughput per thread = 24573.29 KB/sec
Max throughput per thread = 705705.94 KB/sec
Avg throughput per thread = 120635.51 KB/sec
Min xfer = 5056.00 KB
Children see throughput for 32 random readers = 5929731.27 KB/sec
Parent sees throughput for 32 random readers = 4651177.25 KB/sec
Min throughput per thread = 0.00 KB/sec
Max throughput per thread = 1241152.12 KB/sec
Avg throughput per thread = 185304.10 KB/sec
Min xfer = 0.00 KB
Children see throughput for 32 random writers = 417524.02 KB/sec
Parent sees throughput for 32 random writers = 54434.60 KB/sec
Min throughput per thread = 839.97 KB/sec
Max throughput per thread = 59052.09 KB/sec
Avg throughput per thread = 13047.63 KB/sec
Min xfer = 2368.00 KB
VMSTAT output during a test
0 1 0 1837M 1723M 2 0 0 0 0 0 0 0 12976 21628 95554 2 18 81
1 1 0 1837M 1723M 0 0 0 0 0 0 0 0 13717 23124 100732 4 23 72
0 1 0 1837M 1723M 0 0 0 0 0 0 0 0 12924 20699 93545 1 17 82
0 1 0 1837M 1723M 29 0 0 0 0 0 0 0 13287 21942 99070 1 21 78
0 1 0 1837M 1723M 0 0 0 0 0 0 0 0 13536 21483 100533 2 23 75
2 1 0 1837M 1723M 11 0 0 0 0 0 0 0 13549 22777 99822 2 20 79
zpool status:
pool: FREENAS1
state: ONLINE
logs
Machine Specs:
RAM: 12 GB
Record Size 64 KB
Min xfer = 0.00 KB
