Pool Status Offline after Unhealthy and Degraded Disk
jp123
I have 3 disk TrueNAS-12.0-U2. I saw degraded pool with unhealthy cluster. I ran SMART test on problem drive 1 replaced the cable as it is CRC check issue. After reboot I saw another disk 2 has some read write error, so I think cable got loose with drive 2 while changing cable on drive 1. I shutdown again to tighten cables and when I start the system. I see attached message and my ZFS pool is offline now. Need some help to recover the cluster.
