pool offline
duketate
I have FreeBSD 11.3-RELEASE-p7 (FreeNAS.amd64) #0 r325575+ca0f1a6ba25(HEAD): Tue Apr 21 20:46:20 UTC 2020
Since yesterday, it is reporting
Pool NAS-data state is OFFLINE: None.
Sat, 9 Jan 2021 07:07:30 AM (America/Los_Angeles)
root@BiD-NAS[~]# zpool status -v
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:00:19 with 0 errors on Fri Nov 6 03:45:19 2020
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errors
root@BiD-NAS[~]# gpart show
=> 40 468792688 da0 GPT (224G)
40 1024 1 freebsd-boot (512K)
1064 33554432 3 freebsd-swap (16G)
33555496 435224576 2 freebsd-zfs (208G)
468780072 12656 - free - (6.2M)
=> 3 1533547 da1 GPT (7.5G) [CORRUPT]
3 30 2 freebsd-boot (15K)
33 47 - free - (24K)
80 1600 1 efi (800K)
1680 1531870 - free - (748M)
This came without any prior warning about potential problems.
Can anyone please help me? I have a video project stored on that drive and need it recovered ASAP.
Thanks.
So your pool consisted of only one disk? That could only mean you didn't care about your data. Why is it now important?
In any event, it's not at all clear what's going on. da0 appears to be your boot device of ~240 GB. da1 is a ~8 GB device, whose partition table is damaged. Do you have any other disks in the system? camcontrol devlist would let you know if your system sees any other disks; zpool import would show if any pools are available to import.
rvassar
Please describe your hardware in detail per the forum rules. It's critical for those trying to help you to understand your configuration.
duketate
I am using HP ProLiant DL380 Generation 5 (G5) with 8 drives - 1 is an SSD for the OS and the rest are Seagate 2TB drives.
It has 16 Gigs of RAM
What else is needed?
duketate
NO
duketate
No idea what the 8GB dev is. Please see attached, for requested info.
Edit: and what's the 8GB device showing up as da1?
duketate
More info:
version: features support (5000)
Jan 11 15:24:59 BiD-NAS Timecounters tick every 1.000 msec
Jan 11 15:24:59 BiD-NAS freenas_sysctl: adding account.
Jan 11 15:24:59 BiD-NAS freenas_sysctl: adding directoryservice.
Jan 11 15:24:59 BiD-NAS freenas_sysctl: adding middlewared.
Jan 11 15:24:59 BiD-NAS freenas_sysctl: adding network.
Jan 11 15:24:59 BiD-NAS freenas_sysctl: adding services.
Jan 11 15:24:59 BiD-NAS ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
Jan 11 15:24:59 BiD-NAS ipmi0: IPMI device rev. 1, firmware rev. 1.35, version 2.0
Jan 11 15:24:59 BiD-NAS ipmi0: Number of channels 8
Jan 11 15:24:59 BiD-NAS ipmi0: Attached watchdog
Jan 11 15:24:59 BiD-NAS ugen2.1: <Intel UHCI root HUB> at usbus2
Jan 11 15:24:59 BiD-NAS ugen5.1: <HP UHCI root HUB> at usbus5
Jan 11 15:24:59 BiD-NAS ugen4.1: <Intel EHCI root HUB> at usbus4
Jan 11 15:24:59 BiD-NAS ugen0.1: <Intel UHCI root HUB> at usbus0
Jan 11 15:24:59 BiD-NAS ugen1.1: <Intel UHCI root HUB> at usbus1
Jan 11 15:24:59 BiD-NAS ugen3.1: <Intel UHCI root HUB> at usbus3
Jan 11 15:24:59 BiD-NAS uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
Jan 11 15:24:59 BiD-NAS uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus4
Jan 11 15:24:59 BiD-NAS uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
Jan 11 15:24:59 BiD-NAS uhub4: <HP UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus5
Jan 11 15:24:59 BiD-NAS uhub3: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
Jan 11 15:24:59 BiD-NAS uhub5: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
Jan 11 15:24:59 BiD-NAS uhub3: 2 ports with 2 removable, self powered
Jan 11 15:24:59 BiD-NAS uhub0: 2 ports with 2 removable, self powered
Jan 11 15:24:59 BiD-NAS uhub2: 2 ports with 2 removable, self powered
Jan 11 15:24:59 BiD-NAS uhub4: 2 ports with 2 removable, self powered
Jan 11 15:24:59 BiD-NAS uhub5: 2 ports with 2 removable, self powered
Jan 11 15:24:59 BiD-NAS ugen5.2: <HP Virtual Keyboard> at usbus5
Jan 11 15:24:59 BiD-NAS ukbd0 on uhub4
Jan 11 15:24:59 BiD-NAS ukbd0: <Virtual Keyboard> on usbus5
Jan 11 15:24:59 BiD-NAS kbd2 at ukbd0
Jan 11 15:24:59 BiD-NAS ugen5.3: <HP Virtual Hub> at usbus5
Jan 11 15:24:59 BiD-NAS uhub6 on uhub4
Jan 11 15:24:59 BiD-NAS uhub6: <Virtual Hub> on usbus5
Jan 11 15:24:59 BiD-NAS uhub6: 7 ports with 7 removable, self powered
Jan 11 15:24:59 BiD-NAS uhub1: 8 ports with 8 removable, self powered
Jan 11 15:24:59 BiD-NAS ugen4.2: <SanDisk Cruzer Fit> at usbus4
Jan 11 15:24:59 BiD-NAS umass0 on uhub1
Jan 11 15:24:59 BiD-NAS umass0: <SanDisk Cruzer Fit, class 0/0, rev 2.10/1.00, addr 2> on usbus4
Jan 11 15:24:59 BiD-NAS umass0: SCSI over Bulk-Only; quirks = 0x8100
Jan 11 15:24:59 BiD-NAS umass0:4:0: Attached to scbus4
Jan 11 15:24:59 BiD-NAS ugen3.2: <BTC USB Multimedia Keyboard> at usbus3
Jan 11 15:24:59 BiD-NAS ukbd1 on uhub5
Jan 11 15:24:59 BiD-NAS ukbd1: <BTC USB Multimedia Keyboard, class 0/0, rev 1.10/1.00, addr 2> on usbus3
Jan 11 15:24:59 BiD-NAS kbd3 at ukbd1
Jan 11 15:24:59 BiD-NAS da0 at ciss0 bus 0 scbus0 target 0 lun 0
Jan 11 15:24:59 BiD-NAS da0: <HP RAID 0 OK> Fixed Direct Access SPC-3 SCSI device
Jan 11 15:24:59 BiD-NAS da0: Serial Number P61620D9SUS1XJ
Jan 11 15:24:59 BiD-NAS da0: 135.168MB/s transfers
Jan 11 15:24:59 BiD-NAS da0: Command Queueing enabled
Jan 11 15:24:59 BiD-NAS da0: 228902MB (468792765 512 byte sectors)
Jan 11 15:24:59 BiD-NAS da1 at umass-sim0 bus 0 scbus4 target 0 lun 0
Jan 11 15:24:59 BiD-NAS da1: <SanDisk Cruzer Fit 1.00> Removable Direct Access SPC-4 SCSI device
Jan 11 15:24:59 BiD-NAS da1: Serial Number 4C530002021103109482
Jan 11 15:24:59 BiD-NAS da1: 40.000MB/s transfers
Jan 11 15:24:59 BiD-NAS da1: 7632MB (15630336 512 byte sectors)
Jan 11 15:24:59 BiD-NAS da1: quirks=0x2<NO_6_BYTE>
Jan 11 15:24:59 BiD-NAS cd0 at ata0 bus 0 scbus2 target 0 lun 0
Jan 11 15:24:59 BiD-NAS cd0: <TSSTcorp CDW/DVD TS-L462D HG01> Removable CD-ROM SCSI device
Jan 11 15:24:59 BiD-NAS cd0: 33.300MB/s transfers (UDMA2, ATAPI 12bytes, PIO 65534bytes)
Jan 11 15:24:59 BiD-NAS cd0: Attempt to query device size failed: NOT READY, Medium not present - tray closed
Jan 11 15:24:59 BiD-NAS random: unblocking device.
Jan 11 15:24:59 BiD-NAS Trying to mount root from zfs:freenas-boot/ROOT/11.3-U2.1 []...
Jan 11 15:24:59 BiD-NAS GEOM: da1: the secondary GPT table is corrupt or invalid.
Jan 11 15:24:59 BiD-NAS GEOM: da1: using the primary only -- recovery suggested.
Jan 11 15:24:59 BiD-NAS GEOM: iso9660/FREENAS: the secondary GPT table is corrupt or invalid.
Jan 11 15:24:59 BiD-NAS GEOM: iso9660/FREENAS: using the primary only -- recovery suggested.
Jan 11 15:24:59 BiD-NAS (da0:ciss0:0:0:0): SYNCHRONIZE CACHE(10). CDB: 35 00 00 00 00 00 00 00 00 00
Jan 11 15:24:59 BiD-NAS (da0:ciss0:0:0:0): CAM status: SCSI Status Error
Jan 11 15:24:59 BiD-NAS (da0:ciss0:0:0:0): SCSI status: Check Condition
Jan 11 15:24:59 BiD-NAS (da0:ciss0:0:0:0): SCSI sense: ILLEGAL REQUEST asc:20,0 (Invalid command operation code)
Jan 11 15:24:59 BiD-NAS (da0:ciss0:0:0:0): Error 22, Unretryable error
Jan 11 15:24:59 BiD-NAS kernel: lo0: link state changed to UP
Jan 11 15:24:59 BiD-NAS ciss0: *** Temperature now within normal range, Port: 1I, storage system 1
Jan 11 15:24:59 BiD-NAS ciss0: *** Hot-plug drive inserted, Port: 1I Box: 1 Bay: 7
Jan 11 15:24:59 BiD-NAS vmx_init: VMX operation disabled by BIOS
Jan 11 15:24:59 BiD-NAS module_register_init: MOD_LOAD (vmm, 0xffffffff82e1c7f0, 0) error 6
Jan 11 15:24:59 BiD-NAS GEOM_ELI: Device da0p3.eli created.
Jan 11 15:24:59 BiD-NAS GEOM_ELI: Encryption: AES-XTS 128
Jan 11 15:24:59 BiD-NAS GEOM_ELI: Crypto: software
Jan 11 15:24:59 BiD-NAS hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/2/40/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/40/0x67<INT,USR,SYS,REA,WRI>
Jan 11 15:24:59 BiD-NAS ums0 on uhub4
Jan 11 15:24:59 BiD-NAS ums0: <Virtual Mouse> on usbus5
Jan 11 15:24:59 BiD-NAS uhid0 on uhub5
Jan 11 15:24:59 BiD-NAS uhid0: <BTC USB Multimedia Keyboard, class 0/0, rev 1.10/1.00, addr 2> on usbus3
Jan 11 15:25:00 BiD-NAS CPU: Intel(R) Xeon(R) CPU X5450 @ 3.00GHz (3000.06-MHz K8-class CPU)
Jan 11 15:25:00 BiD-NAS Origin="GenuineIntel" Id=0x1067a Family=0x6 Model=0x17 Stepping=10
Jan 11 15:25:00 BiD-NAS Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Jan 11 15:25:00 BiD-NAS Features2=0xc0ce3bd<SSE3,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,DCA,SSE4.1,XSAVE,OSXSAVE>
Jan 11 15:25:00 BiD-NAS AMD Features=0x20000800<SYSCALL,LM>
Jan 11 15:25:00 BiD-NAS AMD Features2=0x1<LAHF>
Jan 11 15:25:00 BiD-NAS VT-x: (disabled in BIOS) HLT,PAUSE
Jan 11 15:25:00 BiD-NAS TSC: P-state invariant, performance statistics
Jan 11 15:25:01 BiD-NAS mountd[1055]: bad exports list line '/mnt/NAS-data/Win': symbolic link in export path or statfs failed
Jan 11 15:25:01 BiD-NAS nfsd: can't register svc name
Jan 11 15:25:01 BiD-NAS ntpd[1109]: ntpd 4.2.8p12-a (1): Starting
Jan 11 15:25:01 BiD-NAS ntpd[1109]: Command line: /usr/sbin/ntpd -g -c /etc/ntp.conf -p /var/run/ntpd.pid -f /var/db/ntpd.drift
Jan 11 15:25:01 BiD-NAS ntpd[1109]: ----------------------------------------------------
Jan 11 15:25:01 BiD-NAS ntpd[1109]: ntp-4 is maintained by Network Time Foundation,
Jan 11 15:25:01 BiD-NAS ntpd[1109]: Inc. (NTF), a non-profit 501(c)(3) public-benefit
Jan 11 15:25:01 BiD-NAS ntpd[1109]: corporation. Support and training for ntp-4 are
Jan 11 15:25:01 BiD-NAS ntpd[1109]: available at https://www.nwtime.org/support
Jan 11 15:25:01 BiD-NAS proftpd[1131]: 127.0.0.1 - ProFTPD 1.3.6 (stable) (built Tue Apr 21 2020 21:21:58 UTC) standalone mode STARTUP
Jan 11 15:25:01 BiD-NAS bce0: Gigabit link up!
Jan 11 15:25:01 BiD-NAS kernel: bce0: link state changed to UP
Jan 11 15:25:41 BiD-NAS ciss0: *** Temperature limit reached, Port: 1I, storage system 1
PCI bridge> at device 28.0 on pci0
Jan 11 15:24:59 BiD-NAS pci12: <ACPI PCI bus> on pcib12
Jan 11 15:24:59 BiD-NAS pcib13: <PCI-PCI bridge> at device 0.0 on pci12
Jan 11 15:24:59 BiD-NAS pci13: <PCI bus> on pcib13
Jan 11 15:24:59 BiD-NAS bce0: <HP NC373i Multifunction Gigabit Server Adapter (B2)> mem 0xfa000000-0xfbffffff irq 16 at device 0.0 on pci13
Jan 11 15:24:59 BiD-NAS bce0: /freenas-releng/freenas/_BE/os/sys/dev/bce/if_bce.c(1281): Management firmware enabled but not running!
Jan 11 15:24:59 BiD-NAS miibus0: <MII bus> on bce0
Jan 11 15:24:59 BiD-NAS brgphy0: <BCM5708C 1000BASE-T media interface> PHY 1 on miibus0
Jan 11 15:24:59 BiD-NAS brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
Jan 11 15:24:59 BiD-NAS bce0: Using defaults for TSO: 65518/35/2048
Jan 11 15:24:59 BiD-NAS bce0: Ethernet address: 00:1b:78:bb:2e:9a
Jan 11 15:24:59 BiD-NAS bce0: ASIC (0x57081020);
Jan 11 15:24:59 BiD-NAS kernel: bce0: link state changed to DOWN
Jan 11 15:24:59 BiD-NAS Rev (B2); Bus (PCI-X, 64-bit, 133MHz); B/C (1.9.6); Bufs (RX:2;TX:2;PG:8); Flags (SPLT|MSI|MFW); MFW (NOT RUNNING!)
Jan 11 15:24:59 BiD-NAS Coal (RX:6,6,18,18; TX:20,20,80,80)
Jan 11 15:24:59 BiD-NAS pcib14: <ACPI PCI-PCI bridge> at device 28.1 on pci0
Jan 11 15:24:59 BiD-NAS pci14: <ACPI PCI bus> on pcib14
Jan 11 15:24:59 BiD-NAS uhci0: <Intel 631XESB/632XESB/3100 USB controller USB-1> port 0x1000-0x101f irq 16 at device 29.0 on pci0
Jan 11 15:24:59 BiD-NAS usbus0 on uhci0
Jan 11 15:24:59 BiD-NAS usbus0: 12Mbps Full Speed USB v1.0
Jan 11 15:24:59 BiD-NAS uhci1: <Intel 631XESB/632XESB/3100 USB controller USB-2> port 0x1020-0x103f irq 17 at device 29.1 on pci0
Jan 11 15:24:59 BiD-NAS usbus1 on uhci1
Jan 11 15:24:59 BiD-NAS usbus1: 12Mbps Full Speed USB v1.0
Jan 11 15:24:59 BiD-NAS uhci2: <Intel 631XESB/632XESB/3100 USB controller USB-3> port 0x1040-0x105f irq 18 at device 29.2 on pci0
Jan 11 15:24:59 BiD-NAS usbus2 on uhci2
Jan 11 15:24:59 BiD-NAS usbus2: 12Mbps Full Speed USB v1.0
Jan 11 15:24:59 BiD-NAS uhci3: <Intel 631XESB/632XESB/3100 USB controller USB-4> port 0x1060-0x107f irq 19 at device 29.3 on pci0
Jan 11 15:24:59 BiD-NAS usbus3 on uhci3
Jan 11 15:24:59 BiD-NAS usbus3: 12Mbps Full Speed USB v1.0
Jan 11 15:24:59 BiD-NAS ehci0: <Intel 63XXESB USB 2.0 controller> mem 0xf9df0000-0xf9df03ff irq 16 at device 29.7 on pci0
Jan 11 15:24:59 BiD-NAS usbus4: EHCI version 1.0
Jan 11 15:24:59 BiD-NAS usbus4 on ehci0
Jan 11 15:24:59 BiD-NAS usbus4: 480Mbps High Speed USB v2.0
Jan 11 15:24:59 BiD-NAS pcib15: <ACPI PCI-PCI bridge> at device 30.0 on pci0
Jan 11 15:24:59 BiD-NAS pci15: <ACPI PCI bus> on pcib15
Jan 11 15:24:59 BiD-NAS vgapci0: <VGA-compatible display> port 0x3000-0x30ff mem 0xf0000000-0xf7ffffff,0xf9ff0000-0xf9ffffff irq 23 at device 3.0 on pci15
Jan 11 15:24:59 BiD-NAS vgapci0: Boot video device
Jan 11 15:24:59 BiD-NAS uhci4: <HP iLO Standard Virtual USB controller> port 0x3800-0x381f irq 22 at device 4.4 on pci15
Jan 11 15:24:59 BiD-NAS usbus5 on uhci4
Jan 11 15:24:59 BiD-NAS usbus5: 12Mbps Full Speed USB v1.0
Jan 11 15:24:59 BiD-NAS ipmi0: <IPMI System Interface> mem 0xf9ef0000-0xf9ef00ff irq 21 at device 4.6 on pci15
Jan 11 15:24:59 BiD-NAS ipmi0: using KSC interface
Jan 11 15:24:59 BiD-NAS isab0: <PCI-ISA bridge> at device 31.0 on pci0
Jan 11 15:24:59 BiD-NAS isa0: <ISA bus> on isab0
Jan 11 15:24:59 BiD-NAS atapci0: <Intel 63XXESB2 UDMA100 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0x500-0x50f irq 17 at device 31.1 on pci0
Jan 11 15:24:59 BiD-NAS ata0: <ATA channel> at channel 0 on atapci0
Jan 11 15:24:59 BiD-NAS acpi_tz0: <Thermal Zone> on acpi0
Jan 11 15:24:59 BiD-NAS atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
Jan 11 15:24:59 BiD-NAS atkbd0: <AT Keyboard> irq 1 on atkbdc0
Jan 11 15:24:59 BiD-NAS kbd0 at atkbd0
Jan 11 15:24:59 BiD-NAS atkbd0: [GIANT-LOCKED]
Jan 11 15:24:59 BiD-NAS acpi_syscontainer0: <System Container> port 0x2e-0x2f,0x4e-0x4f,0x620-0x65f,0x680-0x69f,0x600-0x61f,0x660-0x67f,0x300-0x30f on acpi0
Jan 11 15:24:59 BiD-NAS uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
Jan 11 15:24:59 BiD-NAS ichwd0: <Intel 63XXESB watchdog timer> on isa0
Jan 11 15:24:59 BiD-NAS ichwd0: ICH WDT present but disabled in BIOS or hardware
Jan 11 15:24:59 BiD-NAS device_attach: ichwd0 attach returned 6
Jan 11 15:24:59 BiD-NAS ichwd0: <Intel 63XXESB watchdog timer> at port 0x930-0x937,0x960-0x97f on isa0
Jan 11 15:24:59 BiD-NAS orm0: <ISA Option ROMs> at iomem 0xc0000-0xcafff,0xe6000-0xe7fff on isa0
Jan 11 15:24:59 BiD-NAS atrtc0: <AT realtime clock> at port 0x70 irq 8 on isa0
Jan 11 15:24:59 BiD-NAS atrtc0: registered as a time-of-day clock, resolution 1.000000s
Jan 11 15:24:59 BiD-NAS Event timer "RTC" frequency 32768 Hz quality 0
Jan 11 15:24:59 BiD-NAS uart1: <Non-standard ns8250 class UART with FIFOs> at port 0x2f8 irq 3 on isa0
Jan 11 15:24:59 BiD-NAS coretemp0: <CPU On-Die Thermal Sensors> on cpu0
Jan 11 15:24:59 BiD-NAS est0: <Enhanced SpeedStep Frequency Control> on cpu0
Jan 11 15:24:59 BiD-NAS est: CPU supports Enhanced Speedstep, but is not recognized.
Jan 11 15:24:59 BiD-NAS est: cpu_vendor GenuineIntel, msr 922092206000616
Jan 11 15:24:59 BiD-NAS device_attach: est0 attach returned 6
Jan 11 15:24:59 BiD-NAS coretemp1: <CPU On-Die Thermal Sensors> on cpu1
Jan 11 15:24:59 BiD-NAS est1: <Enhanced SpeedStep Frequency Control> on cpu1
Jan 11 15:24:59 BiD-NAS device_attach: est1 attach returned 6
Jan 11 15:24:59 BiD-NAS coretemp2: <CPU On-Die Thermal Sensors> on cpu2
Jan 11 15:24:59 BiD-NAS est2: <Enhanced SpeedStep Frequency Control> on cpu2
Jan 11 15:24:59 BiD-NAS device_attach: est2 attach returned 6
Jan 11 15:24:59 BiD-NAS coretemp3: <CPU On-Die Thermal Sensors> on cpu3
Jan 11 15:24:59 BiD-NAS est3: <Enhanced SpeedStep Frequency Control> on cpu3
Jan 11 15:24:59 BiD-NAS device_attach: est3 attach returned 6
Jan 11 15:24:59 BiD-NAS coretemp4: <CPU On-Die Thermal Sensors> on cpu4
Jan 11 15:24:59 BiD-NAS est4: <Enhanced SpeedStep Frequency Control> on cpu4
Jan 11 15:24:59 BiD-NAS device_attach: est4 attach returned 6
Jan 11 15:24:59 BiD-NAS coretemp5: <CPU On-Die Thermal Sensors> on cpu5
Jan 11 15:24:59 BiD-NAS est5: <Enhanced SpeedStep Frequency Control> on cpu5
Jan 11 15:24:59 BiD-NAS device_attach: est5 attach returned 6
Jan 11 15:24:59 BiD-NAS coretemp6: <CPU On-Die Thermal Sensors> on cpu6
Jan 11 15:24:59 BiD-NAS est6: <Enhanced SpeedStep Frequency Control> on cpu6
Jan 11 15:24:59 BiD-NAS device_attach: est6 attach returned 6
Jan 11 15:24:59 BiD-NAS coretemp7: <CPU On-Die Thermal Sensors> on cpu7
Jan 11 15:24:59 BiD-NAS est7: <Enhanced SpeedStep Frequency Control> on cpu7
Jan 11 15:24:59 BiD-NAS device_attach: est7 attach returned 6
Jan 11 15:24:59 BiD-NAS ZFS filesystem version: 5
Jan 11 15:24:59 BiD-NAS ZFS storage pool version: features support (5000)
??? Why? It was working fine for months.
Right. Until it didn't any more. There's a reason they're universally discouraged with ZFS. See:
duketate
So, are you saying that there is no hope, or...???
There probably isn't any hope, unless you can recover the array using your RAID controller. However you've configured the array for those seven 2TB disks, your RAID controller is presenting itself to FreeNAS as a 228 GB single disk, so something's clearly gone very badly wrong. And the controller hides all the details from the OS, so FreeNAS has no way of seeing what's going on (and warning you about it, or potentially fixing it). And for some reason, your boot device is on your RAID controller--then you've got a USB stick there not doing anything that I can see.
Do you have any kind of configuration screen for the RAID controller? If this is going to be repairable, I'm thinking that's where it's going to need to happen.
