Hi everyone,
I'm new here !! :)
I've been using Freenas 8 RC4 (I know i'm a little late .. but I never had the guts to upgrade since the disk where full of data and i really needed it to be up and running quickly) for quite a while, with no problems, It's build on an ESXi server
Lately I could not reach my CIFS share .. tried to reach the webGUI ...unreachable, tried to reboot the system within vSphereClient no luck. So I did a reset in vSphere ....(the hard way then) and the system went back to normal :)
Today same symptoms, tried the first 2 solutions same results so I reseted the VM, like last time.
and I could still not reach my CIFS share....so I logged back into the webGUI and this I saw :
additionaly I saw that I have the GEOM: da0s1: geometry does not match label da0s1 being my virtualdisk where Freenas is installed (dunno if it can be related, from what i've seen on other thread maybe not)
Well starting from there I read this thread :
http://forums.freenas.org/showthread.php?1764-Error-getting-used-space-(Error)
Trying an auto import on the webGUI do nothing, there is a drop down menu in the popup that is empty (i guess it should show the pool I'm looking for)
when I looked i /var/log/messages, here is what i see just after hitting the auto import button:
any zpool history or list gives me "no pools available"
a Zpool import gives me no error, but nothing happens in the GUI I still have my errors.
at the end of this thread there is a link to another one
http://forums.freenas.org/showthrea...Issues-Space-Error&p=8448&viewfull=1#post8448
I first check if i I had a "RAIDZ" file in /mnt and there were none.
So I gave it a try too, and i'm having the same issue as the last post of the thread being
doing mount -uw / works
but then the zfs set mountpoint=/mnt RAIDZ (RAIDZ being my pool) gives me 'cannot open RAIDZ: dataset does not exist'
last thing, My pool is mabe of 3 1TB HDD, all are detected by freenas at boot (dmesg) and all three are seen when I click on the "view disk" button of my primary volume in the GUI.
My whole life is in this box please gimme some help, I can't afford to lose everything.
Thanks in advance.
			I'm new here !! :)
Thanks in advance.
